  Removing luggage rack?
Removing luggage rack? by johnt671
Started on: 01-13-2014 06:05 PM
Replies: 5 (963 views)
Last post by: johnt671 on 01-14-2014 08:52 AM
johnt671
Report this Post01-13-2014 06:05 PM Click Here to See the Profile for johnt671Send a Private Message to johnt671Edit/Delete MessageReply w/QuoteDirect Link to This Post
How can I remove the rack for painting? I can see the nuts that hold the spoiler and the back of the runners on the deck, but how is the other end toward the front of the deck held down? Thanks.
Custom2M4
Total ratings: 114
Report this Post01-13-2014 06:11 PM Click Here to See the Profile for Custom2M4Send a Private Message to Custom2M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
If I recall correctly there is glue under there on the center bars.
Edit, I just checked. There are eleven holes under the luggage rack. Push in plastic bushings and double sided tape were holding mine on.
[This message has been edited by Custom2M4 (edited 01-13-2014).]
BrittB
Report this Post01-13-2014 10:11 PM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Remove the rubber inserts and you will find the screws that hold the other pieces in place.
Khw
Total ratings: 134
Report this Post01-14-2014 12:08 AM Click Here to See the Profile for KhwSend a Private Message to KhwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Down the center of each rib on the top side is a rubber strip. That strip can be taken out by prying up on the end with a small flat screwdriver. Once you have it started you will see the grooves on each side that hold it in. Be careful as you pull it out, they are 26+ years old and you can rip the bottom part of the groove in the rubber off. Once you have all the center rubber strips out, you will find all of the screws that hold them to the decklid. Some people have said theirs had double sided tape on them, mine did not. Mine had a plastic gasket under each one but mine was an 84 so maybe that changed over the years.
Total ratings: 466
Report this Post01-14-2014 01:54 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used a pistol grip hair dryer on these rubber inserts to make sure they were soft and flexible as I pulled them out. It helped.
johnt671
Report this Post01-14-2014 08:52 AM Click Here to See the Profile for johnt671Send a Private Message to johnt671Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks to all. Glad I checked, some one told me the other ends were held on with double stick tape. I would have started prying on them and made a mess.
