  Access to the ecm chip.
Access to the ecm chip. by BrittB
Started on: 01-13-2014 10:54 AM
Replies: 3 (163 views)
Last post by: BrittB on 01-13-2014 09:20 PM
BrittB
Report this Post01-13-2014 10:54 AM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is there a way to swap out the chip in my 85 V-6 SE without removing the entire console? I need to install a EGR delete chip into it.
hiwil88formula
Report this Post01-13-2014 11:18 AM Click Here to See the Profile for hiwil88formulaSend a Private Message to hiwil88formulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
No. It only takes about 5-10min to remove to center console.
Blacktree
Total ratings: 350
Report this Post01-13-2014 01:38 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, there isn't. But removing the console is easy. First, unscrew the 4 screws under the ashtrays, so the shifter bezel is loose. Then, move the shifter bezel out of the way so you can remove the 2 screws at the front edge of the rear console. Then open the storage compartment in the rear console, and remove those 2 screws. Flip the rear console forward, and you're done. We're talking 5 minutes, tops.
BrittB
Report this Post01-13-2014 09:20 PM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds easy, I'll give it a go. Thanks!
