  trans / diff locked up
trans / diff locked up by 1988lambo-kit
Started on: 01-09-2014 04:56 PM
Replies: 4 (132 views)
Last post by: tebailey on 01-09-2014 07:43 PM
1988lambo-kit
Report this Post01-09-2014 04:56 PM Click Here to See the Profile for 1988lambo-kitSend a Private Message to 1988lambo-kitEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a kit car based on a 1988 Fiero Gt with a V6 & Getrag 5 speed
I just bought the car and it appears the rear diff or trans is locked.
The car will not roll freely and if we push hard enough to move it, one rear wheel turns clockwise and one turns anti-clockwise
The shift lever in car will go directly forward or back from neutral position but not side to side. It does feel like it engages the shift fork from neutral . ( not just floppiing around)
The engine will run with trans shifter in neutral but as soon as I shift into 1st or 2nd and let out the clutch the engine dies.
Has anyone had similair problem and any suggestions on what to check first ???
lateFormula
Report this Post01-09-2014 06:33 PM Click Here to See the Profile for lateFormulaSend a Private Message to lateFormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If that is the case then the differential is not locked up, but the trans is locked up somehow and power cannot be transferred through it. Something is broken in the transmission, but it does not sound like the differential is the culprit.
Total ratings: 461
Report this Post01-09-2014 07:07 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I agree.
Sounds like the tranny is stuck in two gears. Used to happen to the old GM Saginaw 4 speeds. Never heard of it happening with a Getrag, but I suppose it's possible.
Total ratings: 260
Report this Post01-09-2014 07:16 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the getrag transmission has been apart, it is possible to have one of the shift rails slide out of position during assembly and lock the transmission into 2 gears at the same time...
I normally like learning something new every day, but that day I wasn't so pleased.
On mine, the reverse rail was pushed too deep into the transmission, so I removed the backup light switch and drilled a small hole at an angle on the side to access the end of the shaft and was able to pop it forward w/o taking the transmission apart again.
[This message has been edited by fieroguru (edited 01-09-2014).]
tebailey
Report this Post01-09-2014 07:43 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
That was a common problem with machine that used tractor drive lines. Stuck in 2 gears at once. My old Nash Metro was like that when I bought it, the guy thought he blew the tranny and it was just a shift arm that got bumped when he got it stuck. Popped the lever over and it drove and shifted fine. Check the cables at the shifter and tranny, you might get lucky and find that it's just a cable out of whack.
