  Headlights wont go down.
Headlights wont go down. by Merlinhaggard
Started on: 01-08-2014 12:13 PM
Replies: 13 (898 views)
Last post by: buddycraigg on 12-20-2015 02:10 AM
Merlinhaggard
Report this Post01-08-2014 12:13 PM Click Here to See the Profile for MerlinhaggardSend a Private Message to MerlinhaggardEdit/Delete MessageReply w/QuoteDirect Link to This Post
I turned my headlights on and they went up. I turned them off and they are still up?? What tha. Am I missing something? Im a new fiero owner BTW
ltlfrari
Total ratings: 127
Report this Post01-08-2014 12:38 PM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it's both I'd suspect a relay.
Dave
www.ltlfrari.com
TbirdMarc
Report this Post01-08-2014 12:51 PM Click Here to See the Profile for TbirdMarcClick Here to visit TbirdMarc's HomePageSend a Private Message to TbirdMarcEdit/Delete MessageReply w/QuoteDirect Link to This Post
what year fiero. it matters.
mcguiver3
Report this Post01-08-2014 01:48 PM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
If you need to get them down there is a knob at the rear of the unit that can be manually rotated to raise or lower the light.
It takes a while but it is do-able
Like previously mentioned the year does make a difference on diagnosing the issue.
Report this Post01-08-2014 02:55 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
First Check taillight fuse.
Timpilot
Report this Post01-08-2014 08:34 PM Click Here to See the Profile for TimpilotClick Here to visit Timpilot's HomePageSend a Private Message to TimpilotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Will the headlights go down if you push on the bottom of the headlight switch?
If so, there is a contact inside the switch that is probably oxidized/burned.
On two different Fieros, I've taken the headlight switch apart , cleaned the contacts, and the headlights started operating normally.
I also bent the contacts slightly for better contact.
Merlinhaggard
Report this Post01-08-2014 09:05 PM Click Here to See the Profile for MerlinhaggardSend a Private Message to MerlinhaggardEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its an 85. It will screw down with the knob. I didnt try pushing the button, Ill try that.
Ducati Jones
Report this Post01-09-2014 01:21 PM Click Here to See the Profile for Ducati JonesSend a Private Message to Ducati JonesEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've got a 86. My passengerside head light used to do the same thing. Sometime it would go up and not come down. If I manually put it down it would not go up next time I needed it. I just replaced it all with a GEN2 set up. Check Ebay, the motors and harness are available sometimes.
tuckerfleischmann
Report this Post01-12-2014 12:11 PM Click Here to See the Profile for tuckerfleischmannSend a Private Message to tuckerfleischmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just used the Fiero Stores rebuild kit to replace the gears inside the headlight motors, and afterwords, I had somehow undone the tail light fuse and they would not go down. The tail light fuse affects both the tail lights and the lights on your dash. If you want to check, just turn on your lights at night and see if your dash light is on or off.
85 SE VIN 9
Report this Post01-12-2014 08:51 PM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
This may be intentional on the part of a previous owner. There may be a switch to disable the closing function. Pull the switch and see if the white wire has been cut/rerouted to a switch somewhere. See the Michigan Fiero Club pdf on the subject.
TheDigitalAlchemist
Total ratings: 95
Report this Post01-13-2014 10:21 AM Click Here to See the Profile for TheDigitalAlchemistClick Here to visit TheDigitalAlchemist's HomePageSend a Private Message to TheDigitalAlchemistEdit/Delete MessageReply w/QuoteDirect Link to This Post
Watch your fingers!
I never had any issues working on mine, but be careful
Love, mom
Napoleon_Tanerite
Report this Post12-19-2015 09:28 AM Click Here to See the Profile for Napoleon_TaneriteSend a Private Message to Napoleon_TaneriteEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump. I've got an 87 (so gen 2) and my headlights won't go down without several cyclings of the switch. I already opened the motors and the gears are in good shape, but they DON'T have the three plastic dowels in there, and instead have hard gray plastic filling the entire cavity. Not sure if it's JB welt or what, but everything comes apart if necessary. Should I replace the gears with the proper setup, or replace the relay?
Report this Post12-19-2015 09:57 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
You need the plastic dowels. They offer shock protection for the gears. Can you get the gray crud out?
buddycraigg
Total ratings: 478
Report this Post12-20-2015 02:10 AM Click Here to See the Profile for buddycraiggSend a Private Message to buddycraiggEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok. the OP thread is 2 years old, so I'm guessing his problem is resolved.
Napoleon_Tanerite,
if both of your motors seem to lock up and then both start working at the same time, I would look at a problem with the switch on the dash or the control module.
Start with the switch first, you can take it apart and clean the contacts for free.
if one side seems to work, and the other doesn't, then tell us that and we can help troubleshoot deeper.
[This message has been edited by buddycraigg (edited 12-20-2015).]
