  Anyone used this ?
Anyone used this ? by Lou6t4gto
Started on: 12-30-2013 02:06 PM
Replies: 2 (206 views)
Last post by: Lou6t4gto on 12-30-2013 05:24 PM
Lou6t4gto
Report this Post12-30-2013 02:06 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.ebay.com/itm/190...id=p3984.m1423.l2649 Has anyone used this in their 4t65e installation ? did it give you the "SHIFT feel" you wanted ? work as described ? thanks
Total ratings: 291
Report this Post12-30-2013 05:07 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 4T65E/4T65E-HD has a common problem where the valve body wears out and does not allow the shift pressures to build up quick enough. The PCM senses this, flags the P1811 P0741 trouble and "corrects" the problem by increasing the pressures and shifting to be extremely quick. The transmission will slam the shifts until the car is turned off. The problem normally occurs when the temperature is warm/hot and the transmission shifts are slower. The P1811 P0741 trouble does not illuminate the MIL light but the PCM will retain the code. The usual fix is to install a shift kit like this.
Lou6t4gto
Report this Post12-30-2013 05:24 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
so, it iS a good idea. I have to replace the 4th clutch shaft also. thanks
