  3800 intense stage 1 x blower cam with 1.6, 1.7 or 1.8 roller rocker ???
3800 intense stage 1 x blower cam with 1.6, 1.7 or 1.8 roller rocker ??? by fierogtx
Started on: 12-11-2013 10:23 AM
Replies: 11 (636 views)
Last post by: LFiero67 on 12-16-2013 05:58 PM
fierogtx
Report this Post12-11-2013 10:23 AM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
hi just want to know if many people try the s1x with roller rockers i searched and what i found is many times you need to modify the head for 1.7 and 1.8 roller rockers but i have intense racing stage 3 heads and can go up to .600 lift. i have many mods like gen v intercooler n* tb is3 heads .... do i will have big gain with the 1.7 or 1.8 vs 1.6 roller rockers does it has poeple try the different combo ????? i have a fiero and want some power but dont want to loose all the low rpm range. many thanks all
Justinbart
Total ratings: 119
Report this Post12-11-2013 08:26 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Use stock rockers
Turbo 3800 E85 F23 5spd spec5
10.91@133.1
djlamp14
Report this Post12-12-2013 12:44 AM Click Here to See the Profile for djlamp14Send a Private Message to djlamp14Edit/Delete MessageReply w/QuoteDirect Link to This Post
stay with stock
darkhorizon
Total ratings: 451
Report this Post12-12-2013 10:25 AM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Technically a 1.8 roller would give you more valve at low cam lift areas than stock would, but I am not sure if it would do anything to change the power curve as LSA and duration is not going to change.
fierogtx
Report this Post12-13-2013 09:59 AM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks all just wanted to have some input about that i think i will stay with stock 1.6 rr
Justinbart
Total ratings: 119
Report this Post12-13-2013 12:17 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Stock stock right? Not roller tip.
10.91@133.1
fierogtx
Report this Post12-13-2013 10:03 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
why all say stock and not 1.6 roller rockers i tought it was better the roller because the roller will less damage the valve guide and valve stem tips no ?????
Justinbart
Total ratings: 119
Report this Post12-13-2013 10:12 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Stock is better than a roller tip. The way the tip is designed will give you more lift than a roller tip. ZZP has an article on it somewhere.
10.91@133.1
darkhorizon
Total ratings: 451
Report this Post12-15-2013 10:19 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
stock rockers are equivalent in lift performance to a 1.8 rocker. Its never been proven that 1.8s make more power either.
LFiero67
Report this Post12-16-2013 02:30 AM Click Here to See the Profile for LFiero67Send a Private Message to LFiero67Edit/Delete MessageReply w/QuoteDirect Link to This Post
I made less power with 1.7 rollers than stock. Back to back dyno runs.
10.263 @ 134.44MPH - 1.49 60'
Billet 6262 Precision turbo, PT1001 intercooler, ST1 cam, 130lb springs, comp pushrods, HV3, ARP Rod bolts, otherwise stock L36.
Old M90 XP Cam time -
11.425 @115.60
1.543 60'
fierogtx
Report this Post12-16-2013 10:19 AM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
with the stage 1 x cam or another cam ?????
LFiero67
Report this Post12-16-2013 05:58 PM Click Here to See the Profile for LFiero67Send a Private Message to LFiero67Edit/Delete MessageReply w/QuoteDirect Link to This Post
XP
