  Vacuum lines. Looking for some routing ideas.
Vacuum lines. Looking for some routing ideas. by fisherlr777
Started on: 12-02-2013 03:51 AM
Replies: 1 (348 views)
Last post by: bomluuk on 12-02-2013 03:48 PM
fisherlr777
Report this Post12-02-2013 03:51 AM Click Here to See the Profile for fisherlr777Send a Private Message to fisherlr777Edit/Delete MessageReply w/QuoteDirect Link to This Post
At this point, i'm planning to use the boost bypass solenoid (keeping the boost control valve), and the evap purge solenoid. (any discussion, or reccomendation otherwise would be appreciated)
Is it okay to use the stock 4cyl fiero evap canister? And should i just hook both of its lines to the evap purge solenoid, such as
And where should i connect the fiero body-feed (hvac/brake booster) line to?
[This message has been edited by fisherlr777 (edited 12-02-2013).]
bomluuk
Report this Post12-02-2013 03:48 PM Click Here to See the Profile for bomluukSend a Private Message to bomluukEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is a tree on top of the blower near the throttle body. There should be 1 (total of 3) port that is larger than the others. That's where this connects to.
