  Power Window Problem
Power Window Problem by dallasreese
Started on: 11-28-2013 12:40 PM
Replies: 3 (888 views)
Last post by: 84fiero123 on 11-29-2013 10:02 AM
dallasreese
Report this Post11-28-2013 12:40 PM Click Here to See the Profile for dallasreeseSend a Private Message to dallasreeseEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have an 84 Fiero. I have a power window problem. the window is stuck Midway. I have checked the switch and it is ok and I have checked wiring at door hinge and they seem to be ok. Must be the motor. is there a way to raise the window if the power motor is bad. and also how do you get the panel off the door.?
Spoon
Total ratings: 61
Report this Post11-28-2013 09:35 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
This link might help...
http://www.ehow.com/how_758...se-power-window.html
If you want to remove the door panel you'll need a large and small phillips driver and a panel remover tool. I use a butter knife.
The trim behind door handle comes off; use small phillips. Screws are hidden by a fiero logo and a round cap that prys off. Armrest comes off; large phillips. The panel is attached to the door with plastic clips. I slide a butter knife between panel and door and slide it around the perimeter until you hit a clip and pry panel away from door. Think there are 7 or so clips.
Spoon
dallasreese
Report this Post11-29-2013 08:52 AM Click Here to See the Profile for dallasreeseSend a Private Message to dallasreeseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Spoon. I have taken door panels off before but was not sure if there were anything different with Fieros. Anyway...I will try the muscle up the window and see if that workss. Getting kinda cold out here..haha but thanks again.
Dallas
84fiero123
Total ratings: 325
Report this Post11-29-2013 10:02 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Spoon
Believe it or not we called those plastic Clips at the factory, Carrots. not that it matters as long as we are talking about the same thing, just a factory thing I guess. but when ever I go to the dealer parts department and ask for them I ask for door pad carrots and they know what I am talking about.
Anyway, yes take the door pad off, pull the plug off the window motor and put it on and off a few times, sometimes its just a bad connection at the motor plug from years of corrosion. if the motor is only going up half way it may just be the window is creating resistance in the old guide slots. try running a flat bladed screwdriver up and down the track that the window goes up and down, cleaning that may remove any dirt in the channel.
if that doesn't work it may be a faulty circuit breaker in the fuse panel, if you have a spare try replacing that. the electric windows use a circuit breaker not a fuse and years of use, think holding the window button up or down after it has reached the top or bottom can wear out a breaker.
it can also be you aren't getting juice to the motor, the switch itself is short, again years of use, GM uses a reverse polarity to move the window up and down, my old yard plow, 79 GMC truck the switch went in, so I just hook a battery charger up the motor connections and the motor goes up when you connect the + and - to one side and down when you hook it the other way. that completely eliminates all the switches, breakers and even wires, it will get the window up in a pinch, like now its winter and you need it up. then come summer when the weather is better you can hunt the real problem down when the weather is warmer.
Oh ya GM also have a reversing thing, sorry can't think of the name of it now, when you push the window switch in one direction that tells the thing to send the polarity in one direction and when you push the switch in the other direction it tell it to send the polarity in the other direction.
Anyone of those things can stop the windows movement if they are defective, as well as a bad wire someplace anywhere in the system.
Steve
[This message has been edited by 84fiero123 (edited 11-29-2013).]
