  What clutch for a 3800 n/a?
What clutch for a 3800 n/a? by GODFATHER
Started on: 11-18-2013 11:38 AM
Replies: 6 (263 views)
Last post by: Arns85GT on 11-19-2013 06:42 PM
GODFATHER
Report this Post11-18-2013 11:38 AM Click Here to See the Profile for GODFATHERSend a Private Message to GODFATHEREdit/Delete MessageReply w/QuoteDirect Link to This Post
I did a search but couldn't find a direct answer. What clutch would be recommended for a 3800 n/a with a getrag trans?
Thanks
Joe
Big Paul
Report this Post11-18-2013 12:04 PM Click Here to See the Profile for Big PaulSend a Private Message to Big PaulEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm interested in this as well. Will my spec stage two with 7000 miles be good enough? I'd think it would be.
aaronkoch
Report this Post11-18-2013 05:05 PM Click Here to See the Profile for aaronkochSend a Private Message to aaronkochEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have had really good luck with the HD fiero store clutch kit. It uses OEM parts, holds well, and is easy to modulate. Joe Sokol (Fieroking) also uses them behind his 4.9 swaps with good luck.
I swear it works better than the factory clutch. If you click the last page of my build thread, you can see pics of mine.
mitchjl22
Report this Post11-18-2013 08:51 PM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
I would say yes, but i'm no expert. I have a stage 3 behind my 3800sc, i went with stage 3 only because it was cheaper than stage 2.
NetCam
Report this Post11-18-2013 09:52 PM Click Here to See the Profile for NetCamClick Here to visit NetCam's HomePageSend a Private Message to NetCamEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've got the Spec Stage 3+. It was a bit pricey, but one great clutch.
GODFATHER
Report this Post11-19-2013 09:02 AM Click Here to See the Profile for GODFATHERSend a Private Message to GODFATHEREdit/Delete MessageReply w/QuoteDirect Link to This Post
How harsh are the spec stage 3's? I was thinking stage 1 because it's a stock 3800 n/a and I want it to be smooth . Any other thoughts?
Arns85GT
Total ratings: 202
Report this Post11-19-2013 06:42 PM Click Here to See the Profile for Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
the trick is the "+" which is a kevlar face on the flywheel. It softens the engagement on what otherwise could be a harsh clutch, plus it is very heat resistant.
I have the Spec II + on my 4.9, and it is 417 ft lbs rated which is plenty for the 3800 na
Arn
It is authoritative but smooth
[This message has been edited by Arns85GT (edited 11-19-2013).]
