  Junkyard F23 transmission and engine advice.
Junkyard F23 transmission and engine advice. by dhen
Started on: 11-17-2013 04:57 PM
Replies: 11 (578 views)
Last post by: sco77 on 11-26-2013 08:39 PM
dhen
Report this Post11-17-2013 04:57 PM Click Here to See the Profile for dhenSend a Private Message to dhenEdit/Delete MessageReply w/QuoteDirect Link to This Post
After hearing about how weak my Isuzu transmission is, I went to the junkyard today. I found a manual Cavalier that had the engine already removed. Is this the transmission I want? If so, what should I make sure I pull with it? Do I need the cables, for example?
Also, I can get a whole L67 for less than $500 from the junkyard here if I pull it myself, but it's a gamble, of course. In your experience, are these engines usually OK if they look clean or am I better off paying extra for an Ed Morad engine?
Thanks,
Darian
NetCam
Report this Post11-17-2013 05:05 PM Click Here to See the Profile for NetCamClick Here to visit NetCam's HomePageSend a Private Message to NetCamEdit/Delete MessageReply w/QuoteDirect Link to This Post
My rule of thumb is if the car shows obvious signs of distress - an accident that wrote it off - then that's a good start, because you know there's a good chance that in order to get into an accident the car was roadworthy. Beyond that, look for fluid leaks, and with the tranny you can run it through the gears by hand. As far as cables go, I don't think the stock ones are any good to you, best to use aftermarket. On my swap I have 2 cables, both 75" long. On the L67, does the $500 include the harness and ECM?
dhen
Report this Post11-17-2013 05:13 PM Click Here to See the Profile for dhenSend a Private Message to dhenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks.
Good point on the damage on the outside question.
$500 is for everything - 300 without the supercharger. The car looked to be well cared for but old, so maybe the engine finally died.
I can't get mileage because the batteries are removed.
Edit: That is the correct transmission, though, right?
[This message has been edited by dhen (edited 11-17-2013).]
NetCam
Report this Post11-17-2013 05:18 PM Click Here to See the Profile for NetCamClick Here to visit NetCam's HomePageSend a Private Message to NetCamEdit/Delete MessageReply w/QuoteDirect Link to This Post
Transmission is correct, I have the F23 out of the Cavalier in my 85 GT with 3800sc
Total ratings: 260
Report this Post11-17-2013 06:01 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is a F23, but I would be worried how long the oil fill cap has been off and laying to the side. Transmission might be full of water by now.
dhen
Report this Post11-17-2013 06:46 PM Click Here to See the Profile for dhenSend a Private Message to dhenEdit/Delete MessageReply w/QuoteDirect Link to This Post
It doesn't rain often here in San Antonio, but that's a good point. I put the cap back on and I'll run it through the gears.
FIEROFLYER
Total ratings: 180
Report this Post11-17-2013 09:07 PM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
Unfortunately many an engine and tranny have been ruined because some clown removed a fluid cap or other part and left the engine or tranny exposed to the elements.
I always walk away from these deals as it is not worth the risk of not knowing how much exposure the parts have had. Dan
DARN Cars now open with
rbell2915
Report this Post11-18-2013 07:11 AM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by dhen:
Thanks.
If that person went to an shop to get their oil changed, by looking in the upper left side of the windshield, there will be this sticker informing he or she on when their next oil change is.
darkhorizon
Total ratings: 451
Report this Post11-18-2013 10:22 AM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have had surpisingly good luck with rusty exposed engines in the past.. I wouldnt trust a transmission quite as much unless it has been recently rusty.
dhen
Report this Post11-18-2013 11:23 AM Click Here to See the Profile for dhenSend a Private Message to dhenEdit/Delete MessageReply w/QuoteDirect Link to This Post
I didn't think about that. Thanks!
rbell2915
Report this Post11-18-2013 12:08 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
You're welcome and good luck!
sco77
Report this Post11-26-2013 08:39 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
Another thing is you can bring in a fully charged drill battery and some alligator clamp wires and that usually gives enough power to power the cluster. Of course the key has to be in the car or you'd have to be really good at knowing which wires to jump at ignition.
86 Fiero GT 4spd - L67 swap: VS cam, GenV
98 GTP - Some mods
