  1 more wire ! 3800sc
1 more wire ! 3800sc by Lou6t4gto
Started on: 11-16-2013 01:24 AM
Replies: 3 (171 views)
Last post by: Lou6t4gto on 11-16-2013 01:54 PM
Lou6t4gto
Report this Post11-16-2013 01:24 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
finally putting the pins into the blue and clear plugs. down to the last wire. it is a PINK wire from terminal "B" on the auto trans selector shift/range plug ?, can't find any reference to it ! there is a yellow wire on term B of one of the plugs goes to 68 blue, but cannot find anything on these GMTUNERS sheets about the PINK "B" wire. ( there are 2 plugs on the selector /range mechanism, don't know which is selector & which is range) HELP ! Thanks
mattman134
Report this Post11-16-2013 07:35 AM Click Here to See the Profile for mattman134Send a Private Message to mattman134Edit/Delete MessageReply w/QuoteDirect Link to This Post
The pink wire goes to an ignition on power source. It is the power feed to your backup lights. Pin f on the range switch is the blue wire that goes to your backup lamps, since the range switch is your backup lamp switch.
Total ratings: 291
Report this Post11-16-2013 09:35 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
C500 pin C1 is the switched power source for your back up lights.
C500 pin E1 is the wire that runs to the back up lights.
Lou6t4gto
Report this Post11-16-2013 01:54 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
so, now I need to check the blue wire also. Am I correct that The RANGE Switch has nothing to do with the ENGINE Running ? Undoubtedly this wiring is the Hardest Part of the Entire Project, Thanks
