  Smoke coming out of PCV tube that goes into the intake tube
Smoke coming out of PCV tube that goes into the intake tube by Shonyman32
Started on: 11-12-2013 03:17 PM
Replies: 7 (384 views)
Last post by: Indiana_resto_guy on 11-13-2013 08:00 PM
Shonyman32
Report this Post11-12-2013 03:17 PM Click Here to See the Profile for Shonyman32Send a Private Message to Shonyman32Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is this normal? Engine was recently rebuilt.
1987 3.2 auto. stroked 3.1 bored .040 over.
carbon
Total ratings: 132
Report this Post11-12-2013 03:34 PM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Slowly wafting or forcefully coming out... newly rebuilt engines can have improper ring gap and/or rings that didn't seat. That tube is the fresh air supply for the engine... vacuum is applied to the PCV valve on the other side.
Shonyman32
Report this Post11-12-2013 03:39 PM Click Here to See the Profile for Shonyman32Send a Private Message to Shonyman32Edit/Delete MessageReply w/QuoteDirect Link to This Post
It wasn't forceful but it wasn't just sitting in there.
Like a bunch of Canadians trying to get somewhere fast. <---- Joke but that's what my friend said.
Indiana_resto_guy
Total ratings: 163
Report this Post11-13-2013 08:30 AM Click Here to See the Profile for Indiana_resto_guySend a Private Message to Indiana_resto_guyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does it happen right after you start up or after it gets warm?
After start up could be rings not seated properly or yet.
After getting to temp I consider normal from hot oil, that is what the PCV system is for.
Report this Post11-13-2013 10:14 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
How big is Shelbyville Indiana? You could walk down the block and take a look I suspect.
Shonyman32
Report this Post11-13-2013 03:12 PM Click Here to See the Profile for Shonyman32Send a Private Message to Shonyman32Edit/Delete MessageReply w/QuoteDirect Link to This Post
Shelbyville isn't a very big city but were bigger than that.
Also I have 4500 miles on the motor since it was rebuilt. I hope the rings wore in by now.
The car was completely warm after driving home from work.
Custom2M4
Total ratings: 114
Report this Post11-13-2013 07:23 PM Click Here to See the Profile for Custom2M4Send a Private Message to Custom2M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Isn't shelbyville where cousins can marry each other from the show "the Simpsons?"... Im NOT wondering for personal reasons. Good luck on the smoke.
Indiana_resto_guy
Total ratings: 163
Report this Post11-13-2013 08:00 PM Click Here to See the Profile for Indiana_resto_guySend a Private Message to Indiana_resto_guyEdit/Delete MessageReply w/QuoteDirect Link to This Post
around 20,000
I would imagine that cousins from 'the Simpsons' could get married in shelbyville, but why come all the way from Winnipeg to do so?
After running at normal temp for a while, (I have no idea how far the drive from work may be) a little crankcase smoke is normal. It is mainly made up of hydrocarbons which is drawn off the crankcase to be burned in the combustion process of normal engine operation. The operation under normal conditions of a functioning PVC valve sucks the air out of the crankcase, the fresh air supply for the air draw is provided through the tube from the air intake tubing just before the throttle body that goes to the front valve cover.
You got the black coupe?
[This message has been edited by Indiana_resto_guy (edited 11-13-2013).]
