  Will a 2.5L '86 intake manifold heater hose connection function properly on an '87?
Will a 2.5L '86 intake manifold heater hose connection function properly on an '87? by David Hambleton
Started on: 11-09-2013 10:58 PM
Replies: 6 (387 views)
Last post by: theogre on 11-12-2013 09:07 PM
David Hambleton
Report this Post11-09-2013 10:58 PM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
The '86 2.5L intake manifold heater hose connection is out of the way of the ignition system.
Will the proper function be maintained if the '86 connection is installed at the alternator end of a 1987 intake manifold?
Total ratings: 202
Report this Post11-10-2013 07:22 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
So you have a 1987 and you want to use a 1986 intake manifold on an 87 cyl head?
I don't see why it wouldn't but I would assume that one way was more efficient. I can't really answer your question since I've only ever had an 84 and an 85 for 4 cyls; however, I would suggest you try it, and just keep a close look on the temperature. Make sure you burp the cooling system carefully though... you can crack a head really easily.
David Hambleton
Report this Post11-10-2013 08:34 PM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
[QUOTE]Originally posted by 82-T/A [At Work]:
I'm putting an 87 engine in an 86 car. The 87 has a long heater hose from the transmission side of the manifold to the right side of the frame. The 86 has a short formed hose from the alternator side of the manifold.
I suspect the same internal cavity is accessed by the several plugged holes. I'm thinking of swapping the hose connection locations, not the manifold.
There are many differences between the 86 & 87 ignition & fuel management systems. I'm opting for the way more exotic 87. Lol!
[This message has been edited by David Hambleton (edited 11-10-2013).]
puddlejumper
Report this Post11-12-2013 12:35 PM Click Here to See the Profile for puddlejumperSend a Private Message to puddlejumperEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 85 car with a 87 engine. An extension hose was added from the stock heater hose on the engine manifold to the passenger side .
Report this Post11-12-2013 01:19 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Short answer, yes I think.
When pulling the plug will quickly show coolant or not.
Might need to cut tube to 1 90° and use longer hose with no kinks.
If cut... use 1-2 solder bumps to help keep hose blowing out if a clamp get a little loose. Bumps go on outside next to the cut.
example:
When I change the 87 fittings... I will use other port if possible. It stops leaking coolant from killing the DIS brick.
See my Cave, Heater
David Hambleton
Report this Post11-12-2013 08:00 PM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for the replies. I removed the original hose by cutting the aluminum crimped end. I'm going to use regular heater hose & clamps initially; if any problem develops I'll try the '86 style.
Report this Post11-12-2013 09:07 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
If engine is out.... always replace the fitting. Old fitting can leak from taking apart etc.
