  drop motor mounts required? Will FieroX or WCF mounts work with IC/GenV/N* 3800
drop motor mounts required? Will FieroX or WCF mounts work with IC/GenV/N* 3800 by djlamp14
Started on: 11-08-2013 11:32 AM
Replies: 15 (706 views)
Last post by: nosrac on 11-11-2013 10:02 PM
djlamp14
Report this Post11-08-2013 11:32 AM Click Here to See the Profile for djlamp14Send a Private Message to djlamp14Edit/Delete MessageReply w/QuoteDirect Link to This Post
I heard yesterday that if I run the fierox/WCF motor mounts that my motor will not be even close to fitting. I was told that you need 1" drop motor mounts or a deck lid scoop just to clear my 2.5" IC and blower with the N* throttle body.
These 1" lowering mounts are made by a member called "Whodini". Apparently he is no longer on the boards and doesn't make mounts anymore. Can anyone shed some light on this possible issue for me!
11.8@115mph 1/4 mile 1999 Regal GSX being demodded for swap into a 87 Fiero GT.
11 sec pass>>http://www.youtube.com/watch?v=SQT4X2eBlR8
MountainHiBlue87GT
Report this Post11-08-2013 03:53 PM Click Here to See the Profile for MountainHiBlue87GTSend a Private Message to MountainHiBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
ER......what does this stand for, "IC/GenV/N* 3800"? If this is a GEN V 3800 ALL 3800 series I, II, and III are the same as far as the motor mounts are concerned. If the quote "N*" refers to the transmission I suggest you call WCF.
WCF motor mounts and transmission mounts will work fine if you ease the motor down; talk to Chris West who can explain exactly what to do. Also he may tell you that it may be better to modify just the rear deck as the 1 inch drop may give you an incorrect rear axle geometry or some such and then again he may just make you a shorter set of mounts for use as you have described . Just call and ask.
Regards,
David
1987 Fiero GT - 2006 3800 Series III Drive by Wire; Ported & Polished by TrippleEdge; 1.7 Yella Terra Full Roller Rockers; VS Cam; 3.1" Pulley; Tuning by Darth; WCF CAI & 1 5/8 Stainless Headers; 3" Exhaust; Semi-Built 4T65HD; Power Steering & Much More; MSD Coils & Wires; Porsche (Brembo) Calipers on 13" Viper Rotors; 18X8 TSW Indy Wheels; Paint by Phoenix Auto in California City.
[This message has been edited by MountainHiBlue87GT (edited 11-08-2013).]
qwikgta
Total ratings: 84
Report this Post11-08-2013 04:00 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe he has an 3800 SC with a Gen V blower, a Northstar TB and an intercooler placed between the lower intake and blower. Just a guess, (but I think you know that from looking at what you drive)
[This message has been edited by qwikgta (edited 11-08-2013).]
kikinz24
Report this Post11-08-2013 05:11 PM Click Here to See the Profile for kikinz24Send a Private Message to kikinz24Edit/Delete MessageReply w/QuoteDirect Link to This Post
I agree with qwikgta I do believe thays exactly what he meant.. I do believe with a intercooler it will come close. But nothing a little notch in the decklid can't fix
djlamp14
Report this Post11-08-2013 07:03 PM Click Here to See the Profile for djlamp14Send a Private Message to djlamp14Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry, I was just using standard 3800 world terminology. Didn't know that would be confusing to you guys.
Yes I have a top swapped 3800, genv blower, north star throttle body, 2.5" zzp full stack ic. Do any of you know for sure if it fits? I already know the fast back hatch needs to be trimmed...but that's just for standard 3800sc swaps. If you install an ic it takes a lot more room.
kikinz24
Report this Post11-08-2013 07:42 PM Click Here to See the Profile for kikinz24Send a Private Message to kikinz24Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm guessing you're a gp guy lol I honestly am not sure. Heck I know on a gp the stack fits with exactly 1.75" clearance to the hood. . I've see a few 3800 fiero swaps and this may help you a bit.. does the charger sit higher than the factory alternator with the stack.? If so iits not going to fit without trimming. A basic 3800 sc popped in a fiero doesnt clear the alternator and about 3/4" needs trimmed from the passenger side of the decklid just to clear.
MstangsBware
Total ratings: 459
Report this Post11-08-2013 07:52 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is no vendor making the lowering mounts anymore. FieroAddiction used to and Whodennie did a few sets also I believe. If u want lowering mounts u will have to make up ur own set. If using WCF style mounts u will need to notch the declid to clear the blower and TB. This is not a big issues as the decklid can be filled back in to look stock. Also can trim top rib of SC off to help with clearence issues.
hnthomps
Total ratings: 51
Report this Post11-08-2013 09:03 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the same basic setup installed in a 1988 Mera and there are no clearance problems or deck mods required. However, I believe that the Mera has a higher rear deck lid than a stock Fiero. BTW, the current pulley is a 3.4 inch one.
Nelson
[This message has been edited by hnthomps (edited 11-08-2013).]
LFiero67
Report this Post11-09-2013 02:36 AM Click Here to See the Profile for LFiero67Send a Private Message to LFiero67Edit/Delete MessageReply w/QuoteDirect Link to This Post
It will fit, but you will have to trim the decklid supports on both sides. Likely will have to remove the springs on decklid as well. On mine, with same setup, and GT decklid, I had to remove rear half of each hinge, and the springs to make it fit. The hinge will still function with one bolt on each side, but you will need a prop rod to hold decklid up.
10.263 @ 134.44MPH - 1.49 60'
Billet 6262 Precision turbo, PT1001 intercooler, ST1 cam, 130lb springs, comp pushrods, HV3, ARP Rod bolts, otherwise stock L36.
Old M90 XP Cam time -
11.425 @115.60
1.543 60'
djlamp14
Report this Post11-09-2013 03:23 AM Click Here to See the Profile for djlamp14Send a Private Message to djlamp14Edit/Delete MessageReply w/QuoteDirect Link to This Post
damn its gonna be that close? Like thats shitty having to find a prop rod just to keep it up and not being able to use the gas pistons that keep it up.
MstangsBware
Total ratings: 459
Report this Post11-09-2013 04:55 AM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is exactly what u will have to do then add dual gas struts to keep the decklid up or use prop rod..
darkhorizon
Total ratings: 451
Report this Post11-11-2013 12:33 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
The factory spring setup sucks anyway. They are way overkill, heavy, and function poorly after they are 20 years old.
djlamp14
Report this Post11-11-2013 06:32 PM Click Here to See the Profile for djlamp14Send a Private Message to djlamp14Edit/Delete MessageReply w/QuoteDirect Link to This Post
Alright so what I heard about the lowering mounts was pretty much BS. A little trimming of the hatch and using dual gas struts will allow it to all fit then. Also I'm not cutting on my blower lol Shes too shiny to do that
http://s155.photobucket.com...5933549_o-1.jpg.html
[This message has been edited by djlamp14 (edited 11-11-2013).]
MstangsBware
Total ratings: 459
Report this Post11-11-2013 08:51 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Correct..it has been done 100 times over aleady...Thd lowering mounts that FA built at one time was a nice opition to have though. With WCF style mounts u will have to cut about 1.25 inches or so on both sides of the decklid along with half the hindge.
djlamp14
Report this Post11-11-2013 09:24 PM Click Here to See the Profile for djlamp14Send a Private Message to djlamp14Edit/Delete MessageReply w/QuoteDirect Link to This Post
and those fieroX ones of yours will be no different than WCF? The only difference is yours are thicker?
nosrac
Total ratings: 51
Report this Post11-11-2013 10:02 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah,...someone should reproduce those style mounts....
