  No gas coming to EFI😳 What could be wrong? (Iron Duke '85)
No gas coming to EFI😳 What could be wrong? (Iron Duke '85) by kevin
Started on: 11-07-2013 04:50 PM
Replies: 24 (518 views)
Last post by: kevin on 11-18-2013 05:31 PM
kevin
Report this Post11-07-2013 04:50 PM Click Here to See the Profile for kevinSend a Private Message to kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fellas,
I crank my engine and my EFI is not getting fuel! Where do look for a solution?
Cordially,
kevin
P.s please do not tell me I gotta drop the tank
[This message has been edited by kevin (edited 11-07-2013).]
Report this Post11-07-2013 05:17 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
You ask for advice and then you tell us what advice you don't want.... Well, if you don't hear your fuel pump when you turn the key I have some bad news...maybe.
[This message has been edited by Gall757 (edited 11-07-2013).]
Neils88
Total ratings: 56
Report this Post11-07-2013 05:25 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Possible causes:
Fuel pump
Fuel pump relay
Fuse
Plugged fuel filter
ECM
Plugged fuel sock or fuel lines
Out of gas
Bad wires/grounds...
kevin
Report this Post11-07-2013 05:38 PM Click Here to See the Profile for kevinSend a Private Message to kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Neils88:
Possible causes:
Fuel pump
Fuel pump relay
Fuse
Plugged fuel filter
ECM
Out of gas
I got gas. The fuel filer is new. The ECM is also new. OK, what particular fuse needs to be looked at (replaced?). I'll look at the fuse first, then the fuel pump
Thanks for the reply's sirs.
Cordially,
kevin
FIEROPHREK
Total ratings: 137
Report this Post11-07-2013 05:48 PM Click Here to See the Profile for FIEROPHREKSend a Private Message to FIEROPHREKEdit/Delete MessageReply w/QuoteDirect Link to This Post
The main fuse in question is the "TBI 1" fuse. You will not have a "TBI 2" fuse because your have a 4 cyl.
12.3 is faster than a 13.2
Neils88
Total ratings: 56
Report this Post11-07-2013 07:21 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Cordially,
kevin
After the fuse...check the relay. Do you have a voltmeter? You can listen for the click of the relay, but it's best to disconnect the connector at the firewall that goes down to the pump and see if you're getting a 12V signal going to the pump when the key is turned. If you are, then you can disconnect the fuel line just before the fuel filter (make sure you have a bucket and rags). Should get a stream of fuel when the key is turned on. If you aren't...bad pump (or something bad in the tank, such as plugged sock, or broken hose connector at the pump). If you do get fuel up to the fuel filter, reconnect fuel filter and disconnect AFTER the fuel filter and recheck.
Never assume a replaced part is automatically good...even new parts can be faulty.
Report this Post11-07-2013 07:36 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Stop!
First check valve rockers move when cranking.
No movement then like cam gear went south.
Mean no ignition and ref to ECM.
ECM Will Not "send" injector "signal." (ECM grounds that circuit to inject fuel.)
Both are unused in 2.5.
TBI gets power from ECM fuse.
kevin
Report this Post11-07-2013 09:32 PM Click Here to See the Profile for kevinSend a Private Message to kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fellas,
I should add that my '85 Duke started and ran last week. When I subsequently took apart my HVAC cluster, etc. i forgot to disconnect the battery i think I shorted the fuel pump Is there a fuse under the dash that I need to change?
Cordially,
kevin
PBJ
Total ratings: 147
Report this Post11-07-2013 09:33 PM Click Here to See the Profile for PBJSend a Private Message to PBJEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would want to know if the check engine light is on with key on. I have seen the fuse able link go bad by battery.
Pete
88 3800 turbo...10 sec Quarter Mile Member.
Neils88
Total ratings: 56
Report this Post11-07-2013 09:36 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fellas,
Cordially,
kevin
Perhaps you should check ALL the fuses
84fiero123
Total ratings: 325
Report this Post11-08-2013 07:44 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ayup, grab a pair of needle nose pliers or flat nosed pliers and pull them one at a time, check and put back in if its good, you never know you might not even have a bad fuse, it could be just a bad connection at the fuse and removing and replacing could clean it up enough to make it work.
Steve
kevin
Report this Post11-08-2013 11:42 AM Click Here to See the Profile for kevinSend a Private Message to kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fellas,
I looked at the under dash fuses, one at a time, all good. However, there are two silver 'fuses' which sit right next to each other, upper left corner on the fuse box. Do I need to replace these? What do they do? Could these two items be my problem?
Cordially,
kevin
Report this Post11-08-2013 11:46 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Do you hear the fuel pump for a few seconds wehen you forst turn the key to run?
Also has the car run since the ECM was replaced?
Indiana_resto_guy
Total ratings: 163
Report this Post11-09-2013 11:20 AM Click Here to See the Profile for Indiana_resto_guySend a Private Message to Indiana_resto_guyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fellas,
Cordially,
kevin
If you have power windows those are for them.
Do you have a test light? Check for power on the fuel pump fuse. If no voltage check fuse links.
kevin
Report this Post11-09-2013 12:02 PM Click Here to See the Profile for kevinSend a Private Message to kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes,
I do have power windows, I have a 85 SE. Where do I find the fuel pump fuse? Where can I find the fuse linkss? Dumb question, sure. But that is how you learn.....
Cordially,
kevin
kevin
Report this Post11-09-2013 01:09 PM Click Here to See the Profile for kevinSend a Private Message to kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
kevin
Member since Jan 2000
Pete
Pete,
The Check Engine light does not come on. What and or where is this fusible link "by the the battery?"
Appreciatly,
kevin
Total ratings: 290
Report this Post11-09-2013 01:29 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Make sure your ECM reset connector is plugged together.
kevin
Report this Post11-09-2013 08:06 PM Click Here to See the Profile for kevinSend a Private Message to kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
phonedawgz,
The picture you shared with me, thanks. Where on the Fiero is this picture taken? I am still trying to get fuel to to the EFI.
Cordially,
kevin
[This message has been edited by kevin (edited 11-09-2013).]
Neils88
Total ratings: 56
Report this Post11-09-2013 08:25 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
phonedawgz,
Cordially,
kevin
That's just behind the battery
Neils88
Total ratings: 56
Report this Post11-09-2013 08:27 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Neils88
Member since Aug 2013
List the steps you've done to troubleshoot in detail...
(I'm thinking you may have skipped some steps listed above...)
[This message has been edited by Neils88 (edited 11-09-2013).]
kevin
Report this Post11-10-2013 05:16 PM Click Here to See the Profile for kevinSend a Private Message to kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
[QUOTE]Originally posted by Neils88:
[/QUOTEN
Neils88,
First: I checked all the fuses under the dash--all good
Second: I placed an empty jar under the point where the gas enters the fuel filter, cranked the engine--no gas is entering
Third: I rechecked, and then rechecked again for any possible loose connectors and/or wires
The problem first started when I plugged in my HVAC connector. I am/was putting in my subwoofer system again after an 6 year haitus not driving the FIero. Before plugging in dash HVAC control unit, I DID drive the car. It ran great! No problems. After I parked the FIero, I subsequently then plugged in the HVAC control unit. I then cranked the engine over. I then heard a 'clicking' sound in and around this HVAC unit. The following day, I then attempted to restart the car, and it crtanked, but would not start. The members above have given me some suggestions. It seems to me there must be a fuse, or a another type of relay designed by GM, to protect the fuel pump. Am I correct? What do I do next? I tried to listen for the fuel pump copming on, but since I am working alone and am not adept in electrical stuff, I feed I can only get new ideas from guys like yourself.
Cordially,
kevin
p.s. the electric windows work
Report this Post11-10-2013 05:42 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes there is a fuel pump relay. You should be able to hear the fuel pump because it is right next to you when you start the car....under the armrest. If you hear nothing, check the relay which is on the firewall behind you in the engine compartment.
Total ratings: 290
Report this Post11-10-2013 06:47 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
The fuel pump not priming and the check engine light both are indications that the ECM isn't working. Most likely when an ECM doesn't work it is because the ECM isn't getting what it needs to work.
The ECM reset should be located by the battery on your 85 2.5.
Lets start with this. Test to see if you jumper the fuel pump relay, will the fuel pump then run. First locate the fuel pump relay. It is bolted to the firewall, inside the ENGINE compartment, in a location that is pretty much right behind the driver. Most likely there are more than one relay there. Locate the one with wires that are colored Dk. Gree/White, Orange/White, Tan/Black, and Black or Black/White. Unplug the relay from the socket. There are two tangs that hold the relay in the socket. With the relay unplugged take a U shaped paperclip and stick it in the holes for the Orange/Black and Tan/White. When you do so the fuel pump should run.
If the fuel pump runs that indicates your fuel pump is good and you fuel pump fuse is good.
Neils88
Total ratings: 56
Report this Post11-10-2013 07:10 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I agree with phonedawgz...you need to split the system and find out if the problem is in the tank or out side. Follow his steps to see if bypassing the fuel pump relay works, then let us know for the next step.
kevin
Report this Post11-18-2013 05:31 PM Click Here to See the Profile for kevinSend a Private Message to kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks kindly,
I got to ask you, is there a YouTube video showing me how to do this?
Cordially,
kevin
