  Unknown Dash Connector
Unknown Dash Connector by Midn1ght Driv3r
Started on: 11-07-2013 03:45 PM
Replies: 10 (367 views)
Last post by: DLCLK87GT on 11-08-2013 05:16 PM
Midn1ght Driv3r
Report this Post11-07-2013 03:45 PM Click Here to See the Profile for Midn1ght Driv3rSend a Private Message to Midn1ght Driv3rEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm doing some interior wiring and this connector isn't plugged into anything? What is it?
It comes out right behind the center support. There are 6 or 7 plugs on it I believe
[This message has been edited by Midn1ght Driv3r (edited 11-07-2013).]
Total ratings: 202
Report this Post11-07-2013 05:51 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
By any chance, do you have a larger picture? It's kind of hard to get a perspective of where it is.
Here's a picture of the wiring in my 87 with the dash removed, if that helps...
Bloozberry
Total ratings: 311
Report this Post11-07-2013 07:08 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
How many cavities does it have and what are the colors of the wires leading into it?
Midn1ght Driv3r
Report this Post11-07-2013 07:31 PM Click Here to See the Profile for Midn1ght Driv3rSend a Private Message to Midn1ght Driv3rEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unfortunately I'll be home in a few hours, I'll upload a new photo to try and show a little bit more.
From what I remember, there were 6 or 7 wires going into the plug, and there was:
- light green
- green with black stripe
- yellow
- maybe a tan/brown
Bloozberry
Total ratings: 311
Report this Post11-07-2013 07:47 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
I thought it could be the rear defroster relay but those colors don't match up. It might be the connector for the cruise control stalk, but it's hard to tell until you give more details.
Midn1ght Driv3r
Report this Post11-07-2013 11:10 PM Click Here to See the Profile for Midn1ght Driv3rSend a Private Message to Midn1ght Driv3rEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took some more pictures:
jb1
Report this Post11-08-2013 01:48 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I wondered the same thing on my 85, I seen it a few days ago..
(series II swap in progress)
85GT Northstar/ 4t80e
86GT 3800 n/a
My Build
Bloozberry
Total ratings: 311
Report this Post11-08-2013 07:48 AM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's connector C245 and it's used for cruise control.
Midn1ght Driv3r
Report this Post11-08-2013 09:00 AM Click Here to See the Profile for Midn1ght Driv3rSend a Private Message to Midn1ght Driv3rEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's kinda cool to know. Thanks!
Khw
Total ratings: 134
Report this Post11-08-2013 09:50 AM Click Here to See the Profile for KhwSend a Private Message to KhwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, like just about every car I'm pretty sure they made one wiring harness and used it for all the V6 Automatics no matter the options and one for manuals/4cylman/4cylauto or just one that covered all possibilities. So you end up with wiring that may not be used because an option was not installed. Like my Neon out in the garage. I swapped bumper covers to a model that had fog lights from one that didn't. All the wiring was there for the fog lights, all I had to do was plug them in at the bumper, get the dash switch from the junkyard and put in a fuse.
[This message has been edited by Khw (edited 11-08-2013).]
DLCLK87GT
Report this Post11-08-2013 05:16 PM Click Here to See the Profile for DLCLK87GTSend a Private Message to DLCLK87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
You are exactly right, the wireing harness is set up for all options no matter what your car got when it left the factory. That's why adding in options is basically plug and play for the most part.
