  Brake Woes
Brake Woes by RilesOfSmiles
Started on: 11-02-2013 02:27 PM
Replies: 3 (163 views)
Last post by: theogre on 11-03-2013 11:44 AM
RilesOfSmiles
Report this Post11-02-2013 02:27 PM Click Here to See the Profile for RilesOfSmilesSend a Private Message to RilesOfSmilesEdit/Delete MessageReply w/QuoteDirect Link to This Post
I changed the left rear brake caliper on my 88 formula and everything went fine. So I went to replace the right side brake pads and when I tried to put it back together I couldn't push the piston in. The piston pushes out fine but I can't get it back in. No amount of clamping or squeezing will push it in. I even opened the bleeder screw to relieve the pressure in the caliper (don't worry I pinched off the brake line) and it didn't help. It squeezed a minimal amount of fluid out. No issues bleeding the caliper either. But I just don't get why it won't go back in when it was fine before I replaced the other caliper.
Then I noticed a small tear in the seal around the piston so I'm just going to replace it anyway but I wan't to know what went wrong. Why did it appear to seize at the same time I replaced the other caliper?
Slider pins are stuck too.
[This message has been edited by RilesOfSmiles (edited 11-02-2013).]
Neils88
Total ratings: 56
Report this Post11-02-2013 02:39 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Did you screw in the parking brake? It's self adjusting and so needs to be returned to it's screwed in position when replacing pads.
Edit: Check out Ogre's Cave for parking brake adjustment
[This message has been edited by Neils88 (edited 11-02-2013).]
Report this Post11-02-2013 04:20 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
one side goes one way and the other side goes the other way.
Report this Post11-03-2013 11:44 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Clamp method need P brake level REMOVED from caliper.
Bad/rebuilt piston can stop retracting the piston.
see https://www.fiero.nl/forum/F.../HTML/130470.html#p4
