  Headlights Pop Up, Wont Go back Down, Parking Lamps Won't Come on No Ding
Headlights Pop Up, Wont Go back Down, Parking Lamps Won't Come on No Ding by mitchjl22
Started on: 11-02-2013 01:48 PM
Replies: 4 (338 views)
Last post by: mitchjl22 on 11-02-2013 09:15 PM
mitchjl22
Report this Post11-02-2013 01:48 PM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
85' GT Auto 2.8
I was installing new dash bulbs yesterday, and I think something happened to the headlamp circuit. I put everything back together, and last evening, I put the headlights on to see what the new bulbs looked like, the headlights popped up and powered on, the parking lamps were off, the instrument cluster was off, the chime was off. If I turned the switch off, and then depressed it lightly, the parking lights, chime, and instrument lights would come on. In any position on the switch, the headlights would not return back down. The car has 60,000 miles, the original headlights, and from what I know all stock components. I thought that the switch was bad, so I swapped it out and that wasn't the case. What could the problem be. (PS. I also installed a new stereo.)
-Mitch
Edit to add video:
[This message has been edited by mitchjl22 (edited 11-02-2013).]
pontiacfierokid1985
Report this Post11-02-2013 04:13 PM Click Here to See the Profile for pontiacfierokid1985Click Here to visit pontiacfierokid1985's HomePageSend a Private Message to pontiacfierokid1985Edit/Delete MessageReply w/QuoteDirect Link to This Post
There are fusible links on the headlight harness check and see if ur getting power coming out after the fusible link could of blown
AL68
Report this Post11-02-2013 04:24 PM Click Here to See the Profile for AL68Send a Private Message to AL68Edit/Delete MessageReply w/QuoteDirect Link to This Post
check your tail light fuse in the dash fuse block - may have blown if radio not wired right or shorted (fuse supplies power for radio night illumination also)
[This message has been edited by AL68 (edited 11-02-2013).]
Report this Post11-02-2013 04:57 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yup...
If blown then find why.
mitchjl22
Report this Post11-02-2013 09:15 PM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fuse blown. The orange illum wire was partially exposed and shorting on the cage of the new stereo. I cut and taped it. The rest of the woting harness was soldered and heatshrinked.
