  COOLANT
COOLANT by rcm
Started on: 10-29-2013 06:56 PM
Replies: 14 (234 views)
Last post by: rcm on 10-31-2013 10:05 PM
rcm
Report this Post10-29-2013 06:56 PM Click Here to See the Profile for rcmSend a Private Message to rcmEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is there any reason why I cant use a 2.5 qt universal recovery tank.
Report this Post10-29-2013 07:09 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
No. Fiero store used to have the right tank but I don't see it now.
[This message has been edited by Gall757 (edited 10-29-2013).]
rcm
Report this Post10-29-2013 07:21 PM Click Here to See the Profile for rcmSend a Private Message to rcmEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had seen that they may or may not be reproduced.I kinda need one now because mine has a hole in it.
Report this Post10-29-2013 07:26 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Have you ever patched polyethylene with a soldering gun? It's do-able.....a bit messy.
rcm
Report this Post10-29-2013 07:29 PM Click Here to See the Profile for rcmSend a Private Message to rcmEdit/Delete MessageReply w/QuoteDirect Link to This Post
yeah actually I use a little heat and melt plastic on top of hole but it really looks like crap and still leaks.
Report this Post10-29-2013 07:31 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
I may have an extra one.... will look tomorrow.
rcm
Report this Post10-29-2013 07:48 PM Click Here to See the Profile for rcmSend a Private Message to rcmEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok let me know...Thanks
Report this Post10-30-2013 11:54 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is it the threads? I have used teflon tape in the past. The recovery tank shouldnt get full enough to leak out the cap though unless your radiator cap is bad.
rcm
Report this Post10-30-2013 12:32 PM Click Here to See the Profile for rcmSend a Private Message to rcmEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is leaking because it has a hole in ther side of it.
Report this Post10-30-2013 01:38 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Id try a two part epoxy.
rcm
Report this Post10-30-2013 02:52 PM Click Here to See the Profile for rcmSend a Private Message to rcmEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am dealing with 27 year old plastic that has become brittle.I don't mind a good used tank
or a universal tank.Just need something functional that's why I asked if it would work.
I figured somebody possibly went that route.
yooper-kazoo
Report this Post10-30-2013 03:18 PM Click Here to See the Profile for yooper-kazooSend a Private Message to yooper-kazooEdit/Delete MessageReply w/QuoteDirect Link to This Post
I actually had the same problem as you, I used the 2.5 universal tank made by inderdynamics. The kit is a royal pain to install and the tubing provided is garbage, as the tank leaks a little around the petcock area. I even used hose clamps that I bought separately but it still leaks.
Report this Post10-30-2013 03:39 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Junkyard tank would be a good one too. The three I have had havent been brittle, but I suppose it could be that dry Texas air. A wanted ad in the mall should get you some, maybe from a northern state.
rcm
Report this Post10-30-2013 04:23 PM Click Here to See the Profile for rcmSend a Private Message to rcmEdit/Delete MessageReply w/QuoteDirect Link to This Post
yeah it really is the heat down here.Last summer we hit 113.This summer it was a cool front it only hit 108.......
rcm
Report this Post10-31-2013 10:05 PM Click Here to See the Profile for rcmSend a Private Message to rcmEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does anybody know of another supplier for a new tank beside the fiero store?
