  alternator wont charge?
alternator wont charge? by northstar
Started on: 10-23-2013 06:37 PM
Replies: 8 (269 views)
Last post by: Gall757 on 10-24-2013 06:22 PM
northstar
Report this Post10-23-2013 06:37 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
86 se. 4.9. Switched over to carb. And distributor..got an alternator with a built in regulator.it wont turn on..what do I need to do to activate the charging of the alternator. ??
Report this Post10-23-2013 07:25 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have a working volts light?
northstar
Report this Post10-23-2013 08:34 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
No lights on in the dash..does it need a signal from somewhere to kickstart the ALT.? I even ran a heavy wire from the main positive output pole on the alternater to the battery..figuring that the ALT. Would see low voltage and start charging..this is a good ALT. I had it checked today.i know I read somewhere on here that you must have a batt. Light in the dash that somehow has something to do with charging.
Report this Post10-23-2013 08:47 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes Sir!
The little light bulb is the circuit that says 'Charge' to the alternator. Fix the bulb and your problems should be over.
edit: if you have the aux. gauge cluster like the GT, it's in there.
[This message has been edited by Gall757 (edited 10-23-2013).]
SERGE144
Report this Post10-23-2013 09:06 PM Click Here to See the Profile for SERGE144Send a Private Message to SERGE144Edit/Delete MessageReply w/QuoteDirect Link to This Post
I ran into the same thing - changed the bulb while it was running and you could instantly feel the load on the motor change and the volts came up of course.
northstar
Report this Post10-23-2013 09:12 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will give that a try first thing tomorrow thanks to each of you..c
Report this Post10-24-2013 10:05 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unless you use a "1 wire" alt...
Needs 2 things...
1. alt light circuit must be good, as noted above
2. sense wire must be good
See my Cave, Alternator Sense
If use CS alt, CS Alternator
northstar
Report this Post10-24-2013 05:27 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
it seems the brown wire running from my alt. goes into the computer do i need the cars original computer to run the alt.>??
Report this Post10-24-2013 06:22 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
no.
