  what kind of muffler to put on my 3.4l
what kind of muffler to put on my 3.4l by fatalambition16
Started on: 10-17-2013 10:13 PM
Replies: 13 (265 views)
Last post by: JCircs on 10-22-2013 10:40 PM
fatalambition16
Report this Post10-17-2013 10:13 PM Click Here to See the Profile for fatalambition16Send a Private Message to fatalambition16Edit/Delete MessageReply w/QuoteDirect Link to This Post
hey guys im in the process of putting a 3.4l pushrod engine in my 87 gt and even though i should worry about reassembling everything im already thinking ahead of how my car is going to sound. so anyways i am just looking for a muffler to replace my stock one. all im really looking to do is, cut the old one out and weld a new (hopefully more mean) one in. any ideas on where or what to get? which ones sound better than another? thanks in advance!
MaxCubes
Report this Post10-17-2013 10:28 PM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just my opinion...
Flow masters sound good
Magnaflows flow better
Total ratings: 154
Report this Post10-17-2013 10:54 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you don't have emissions inspections, consider just removing the catalytic converter. My 87 with a 3.4, stock muffler with no cat sounds reasonably aggressive, both at idle and at throttle but is still soft on the ears at highway cruising speeds.
fatalambition16
Report this Post10-17-2013 11:59 PM Click Here to See the Profile for fatalambition16Send a Private Message to fatalambition16Edit/Delete MessageReply w/QuoteDirect Link to This Post
i was debating about just taking the cat out and going straight pipes but if i ever moved to somewhere where they require emissions i would have to put one in. thats why im thinking just a muffler emplacement.
Total ratings: 154
Report this Post10-18-2013 12:18 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
It could be accomplished pretty easily. If you cut out the cat, then had a muffler shop cut a length of pipe about 6 inches longer, flare it on the upstream end so it would slip over the header downpipe, and reduce the downstream end so it would slip into the exhaust end, you could clamp it as a non-welded pipe. Then if you needed, just reweld the cat as the spacing would already be correct. It would also be easy to go back with the cat and different muffler if the sound wasn't what you wanted.
Total ratings: 207
Report this Post10-18-2013 09:52 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Stock muffler with no cat sounds good.
You will not notice a difference in sound between the 2.8 and the 3.4.
Blacktree
Total ratings: 350
Report this Post10-18-2013 10:56 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think it depends on what type of sound you want. If you could tell us that, we can give better recommendations.
dobey
Total ratings: 371
Report this Post10-18-2013 11:01 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Keep a cat. Having it there or not doesn't make any huge difference in sound or performance. A new replacement cat will flow well more than the engine needs to.
I have the Pacesetter cat-back system with "performance" cat from The Fiero Store on my 2.8 car. It flows well and is plenty aggressive. It, the Borla, or the Spintech muffler are probably the most "aggressive" sounding ones that you'll find anywhere that are made to fit in as stock replacements for the Fiero.
fatalambition16
Report this Post10-22-2013 02:30 PM Click Here to See the Profile for fatalambition16Send a Private Message to fatalambition16Edit/Delete MessageReply w/QuoteDirect Link to This Post
im mostly looking for an aggressive muscle v8 kind of sound. i like the idea of cutting the cat out and putting the clamp on. but ive also heard some 3.4l camaro/firebird straight pipes and some sounded good however others were awful, it just sounded like a rattle can or something at high rpms.
fatalambition16
Report this Post10-22-2013 02:32 PM Click Here to See the Profile for fatalambition16Send a Private Message to fatalambition16Edit/Delete MessageReply w/QuoteDirect Link to This Post
fatalambition16
Member since Jan 2012
have any part numbers for the spintech or other mufflers?
dobey
Total ratings: 371
Report this Post10-22-2013 03:16 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.westcoastfiero.com/exhaust/muffler.html
http://fierostore.com/Product/Detail.aspx?s=54406
A simple search or two would have landed you with those results. I don't think the Borla Fiero-specific system is available any more, but you could find one of their mufflers that will likely fit in the stock Fiero location.
No matter what you do though, you're not going to have it sound like a V8. If you want a V8 sound, swap in a V8. It's the only way you're going to get it. The V6 Fiero sound is fairly aggressive with stock exhaust, and even more so with any of those mufflers or systems. However, it's not a deep V8 sound, if that's what you're expecting, and it will be a bit raspy, especially in higher RPMs. The stock 2.8 falls off after about 4000 RPM anyway, so revving much higher than that before shifting, is pretty much a total waste of gas. All you're doing at that point is making noise.
fatalambition16
Report this Post10-22-2013 09:18 PM Click Here to See the Profile for fatalambition16Send a Private Message to fatalambition16Edit/Delete MessageReply w/QuoteDirect Link to This Post
i did search that and i am not going to pay $180 for the muffler/exhaust. i think im going with the flowmaster 40 series for $75 and ill clamp it in or my brother in law may weld it in for me. thanks for everyones help!
Sparkys 88GT
Report this Post10-22-2013 09:35 PM Click Here to See the Profile for Sparkys 88GTSend a Private Message to Sparkys 88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am running the Ocelet cat back exhaust with out the cat. I often get asked if I have a V8 in my GT. It's easy enough to put the cat back in if you need it.
JCircs
Report this Post10-22-2013 10:40 PM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I went with spintech, search YouTube for Fiero Spintech 3.4 and you can hear it.
