  3rd brake light not working
3rd brake light not working by indyguy888
Started on: 10-15-2013 04:05 AM
Replies: 6 (301 views)
Last post by: indyguy888 on 10-26-2013 04:14 PM
indyguy888
Report this Post10-15-2013 04:05 AM Click Here to See the Profile for indyguy888Send a Private Message to indyguy888Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have an 88 ttop 2.5 with a 3rd brake light. I need it to be working for inspection. The garage said he put a meter to it and no power going to the bulb. Bulb looks good. Is there a fuse for it ? Any ideas ? Thanks in advanced.
CowsPatoot
Total ratings: 84
Report this Post10-15-2013 04:29 AM Click Here to See the Profile for CowsPatootClick Here to visit CowsPatoot's HomePageSend a Private Message to CowsPatootEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fuse number 7
In most cars, the 3rd brake light runs off a different fuse than the main brake lights...but it appears to be the same one in the Fiero. They do run off separate terminals on the switch, though....so it is possible that it is a bad switch, or a broken/loose wire between the switch and the brake light. There is also a potential terminology issue with how the mechanic checked for power. I translate that as "there is no 12v+ reaching the bulb"....but if he just checked for voltage between one side of the bulb to the other, then I would suspect a grounding issue.
Rodney
Total ratings: 267
Report this Post10-15-2013 05:11 AM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
This happened to my 88. Was the switch on the brake pedal. The switch has 2 contacts. One for brake lights and one for the third brake light. So one can work while the other does not work. It is easy to test with a meter. I replaced it with a good used one out of a junk yard car. Has been fine since.
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Phone/Fax (262) 835-9575
Report this Post10-15-2013 06:18 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I had this issue on my 88, it was the switch on the brake pedal.
indyguy888
Report this Post10-17-2013 02:56 AM Click Here to See the Profile for indyguy888Send a Private Message to indyguy888Edit/Delete MessageReply w/QuoteDirect Link to This Post
Update. I greatly appreciated everyones input. I ran a volt meter to the socket myself. 11.7 volts. So I guess the guy at the garage never checked it in the first place. So I guess the bulb is bad. I am going to replace it Friday.
Report this Post10-17-2013 09:38 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Make sure you use right bulb #... Wrong one can melt the parts, even cause fires.
See my Cave, Lighbulbs
indyguy888
Report this Post10-26-2013 04:14 PM Click Here to See the Profile for indyguy888Send a Private Message to indyguy888Edit/Delete MessageReply w/QuoteDirect Link to This Post
One last update. I put a new bulb in it #889. It still would not light. Good ground, reading voltage. So I took your guys advise and changed the switch. Low and behold it lights up like a Christmas tree. I can't thank you guys enough for the advise. Now I can get the inspection sticker put on it. Have a great day.
