  Pressing water pump pulley on to pump - L4 1987
Pressing water pump pulley on to pump - L4 1987 by z1motorcars
Started on: 10-12-2013 08:55 AM
Replies: 12 (1266 views)
Last post by: z1motorcars on 10-12-2013 04:21 PM
z1motorcars
Report this Post10-12-2013 08:55 AM Click Here to See the Profile for z1motorcarsSend a Private Message to z1motorcarsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm changing the water pump on my 1987 Fiero L4 Iron Duke. I used the Harbor Freight tool to pull the pulley while the water pump was on the car, worked great and made removing the bolts easy (there were only six, I thought there were supposed to be seven.) I want to put the water pump back on the car without the pulley and press it on afterwards; it's easier and I think I can get a nice gasket seal that way. Question is once the water pump is back on how do I press the pulley on. I'm pretty sure I read a thread were someone did this, there was a picture of the completed job nut no mention on how it was done. Any thought would be much appreciated.
Thank you, Bernie
Dodgerunner
Total ratings: 323
Report this Post10-12-2013 09:19 AM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Never worked on the 4 water pump but if it's the replacement pump you have to press back on you really need to do it before install so you can support the impeller end of the shaft while pressing. To do so otherwise could damage the bearings and seal in the pump.
My 2 cents anyway.
[This message has been edited by Dodgerunner (edited 10-12-2013).]
tebailey
Report this Post10-12-2013 09:35 AM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ditto. The shaft end has to be supported when pressing on the pulley. The bearing can move in the housing and cause the impeller to hit the back of the pump. I've rebuilt thousands of water pumps in my life and have screwed them just about every way possible.
z1motorcars
Report this Post10-12-2013 10:13 AM Click Here to See the Profile for z1motorcarsSend a Private Message to z1motorcarsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I owned a machine shop in the 80's but I don't remember every pressing a pulley. What are your contact points, it can't be the impeller.
ckrummy
Report this Post10-12-2013 10:24 AM Click Here to See the Profile for ckrummySend a Private Message to ckrummyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is the end threaded? if so you just need a long bolt a nut and a washer, that's how power steering pumps work.
z1motorcars
Report this Post10-12-2013 10:30 AM Click Here to See the Profile for z1motorcarsSend a Private Message to z1motorcarsEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is and it would be a perfect way to press the pulley back on. The problem I see is the impeller shaft spinning rather then the bearing pressing on. Greasing the shaft would certainly help. Am I missing something?
Report this Post10-12-2013 11:19 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Press support the shaft above is wrong.
You need same press as PS pump. You press the pulley on or off the car.
Is awkward on the car but can be done. Awkward because tool often fits under battery tray. Is hard to get at the end to stop screw from turning.
If you have bad motor mount, need to carefully jack motor so tool has enough room.
Do Not you air tools to press on the pulley.
You can try to remove other parts to get access to the press... Watch heater hose to intake manifold that's easy to damage. See my Cave, Heater
Google: power steering pulley removal
Example tool (HF)
Tip... Pulley stuck to remove? warm the pulley hub only. Warm to your hand is all. Warming the hub can "break" rust etc.
Just use WD40 etc to push the pulley on the WP.
z1motorcars
Report this Post10-12-2013 11:41 AM Click Here to See the Profile for z1motorcarsSend a Private Message to z1motorcarsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you, your website is awesome.
The pulley is off, not a big problem. The old battery tray was all rusted, I built a new one and just unbolted it so I have plenty of room in that area.
What I'm trying to do is mount the new water pump without the pulley, much easier to get to the bolts and I'll get a good gasket seal. Then, with the water pump on, I want to press the pulley back on. Any suggestions would be very much welcome.
Quick question, I only took 6 bolts out of the water pump, aren't there supposed to be 7.
Thank you.
Report this Post10-12-2013 12:08 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
I remove/push the pulley on the car.
# of bolt, 7 short, 1 bigger and long for AC bracket
z1motorcars
Report this Post10-12-2013 03:43 PM Click Here to See the Profile for z1motorcarsSend a Private Message to z1motorcarsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry to be dense, "push" the pulley on the car in what way.
Well, the water pump was missing a bolt, it only had 6. I never payed attention to the air conditioning, it never worked, not that hot up here. My density kicked in again, it was easy to remove the a.c. bracket, no compressor.
Report this Post10-12-2013 03:57 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Push
push on/installed the pulley in the car w/ press kit.
Dead A/C the use none A/C belt.
[This message has been edited by theogre (edited 10-12-2013).]
tebailey
Report this Post10-12-2013 04:11 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The pumps I rebuilt did not have threaded shafts. Therefore the pulley had to be pressed on by supporting the shaft.
z1motorcars
Report this Post10-12-2013 04:21 PM Click Here to See the Profile for z1motorcarsSend a Private Message to z1motorcarsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good to know. I didn't buy a new water pump yet. The one that came off the car does have a threaded shaft.
