  Trunk release wiring
Trunk release wiring by Lurate
Started on: 10-08-2013 03:33 PM
Replies: 1 (257 views)
Last post by: DaytonTD on 10-08-2013 05:42 PM
Lurate
Report this Post10-08-2013 03:33 PM Click Here to See the Profile for LurateClick Here to visit Lurate's HomePageSend a Private Message to LurateEdit/Delete MessageReply w/QuoteDirect Link to This Post
anybody know how to wire the Fiero trunk release to a 3 prong switch? I 'm in the middle of a Amida 355 interior installation and can't figure out how to wire it to his 3 prong switch.
DaytonTD
Report this Post10-08-2013 05:42 PM Click Here to See the Profile for DaytonTDSend a Private Message to DaytonTDEdit/Delete MessageReply w/QuoteDirect Link to This Post
You need to first figure out what each prong does. If one is power, then the other should be a completed cicuit when not pressed and the third is circuit completer when pushed. If it is this then it will be simple to hook up. Does the switch have a light in it?
If does not have a light, then you want to hook the Fiero orange wire (at the original switch) to the power prong, then the grey with black strip (at the original switch) to the output prong when the button is pressed. The third prong does not need to be used unless it is an illuminated switch, then that third one might be a secondary power for the light OR a ground, in which case it may need a different hook up.
