  car shakes at low rpm, sputters a bit, sounds off
car shakes at low rpm, sputters a bit, sounds off by Phirewire
Started on: 10-03-2013 05:51 PM
Replies: 4 (177 views)
Last post by: Phirewire on 10-04-2013 05:30 PM
Phirewire
Report this Post10-03-2013 05:51 PM Click Here to See the Profile for PhirewireSend a Private Message to PhirewireEdit/Delete MessageReply w/QuoteDirect Link to This Post
The other day my car seemed to act up at low rpm, sputters a bit shakes kinda hard at low rpm.
Its a 86 v6 auto, and this suddenly happened. I figured it was my ECM cause this has happened before, i swapped it still running same way. high rpm its fine, just cruising along 60+. I only have the issue at lower speeds.
It has a steady idle/vacuum. I can not check engine codes as my car won't go in diagnostic mode.
Report this Post10-03-2013 06:36 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
I bet you lost one cylinder, but you really should fix the diagnostic thing.
Phirewire
Report this Post10-03-2013 07:23 PM Click Here to See the Profile for PhirewireSend a Private Message to PhirewireEdit/Delete MessageReply w/QuoteDirect Link to This Post
You would notice that in the vacuum wouldn't you? Also, I've played with it , can't seem to located the reason of it.
Report this Post10-04-2013 09:16 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Your ALDL connector may be upside-down.
Phirewire
Report this Post10-04-2013 05:30 PM Click Here to See the Profile for PhirewireSend a Private Message to PhirewireEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wish It was that simple its upside down but I was aware of that
