  So why not a superturbo ?
So why not a superturbo ? by Tweeder
Started on: 10-01-2013 11:33 AM
Replies: 22 (466 views)
Last post by: Tweeder on 10-03-2013 03:33 PM
Tweeder
Report this Post10-01-2013 11:33 AM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was reading the diesel power mag at work today and they have an article in there about Banks did a super/ turbo motor in a rig. It used a whipple twin screw that was fed by a turbo. I know people on here say the turbo boost will be restricted due to the supercharger. It does make sense, but why are they as well as others they reference able to do it and not us? Is it because it's a diesel?
Tweeder
Report this Post10-01-2013 11:40 AM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
Heres a different article on it.
http://m.trucktrend.com/kra...eak_truck/index.html
A quick google showed others.
IROCTAFIERO
Report this Post10-01-2013 01:11 PM Click Here to See the Profile for IROCTAFIEROSend a Private Message to IROCTAFIEROEdit/Delete MessageReply w/QuoteDirect Link to This Post
It can be done, it just isnt for a reason.
cost, complexity, heat, etc
Someone had a Series 1 3800 that was twincharged. They claimed it made plenty of power but they had lots of issues with tuning, etc.
A well-planned turbo setup is your best bet if you want a wild Fiero.
dobey
Total ratings: 371
Report this Post10-01-2013 02:15 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's certainly doable. And it's a lot easier to do on a larger displacement engine like that, where you're going to make a lot more power on less boost. On smaller engines that people put in Fieros, it's a waste of time and money, because tuning it is a pain, and it's not cheap or easy to fit.
Tweeder
Report this Post10-01-2013 03:17 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why would tuning be any worse? I wouldn't mind as I have a turbo sitting on the shelf.
Fiero84Freak
Report this Post10-01-2013 03:31 PM Click Here to See the Profile for Fiero84FreakSend a Private Message to Fiero84FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
You have a much larger tuning "window" with something that big. You don't necessarily have to be incredibly precise on tuning to make power and potentially some corners can be cut or you can make a large amount of power gains, while still losing some potential gains and it not being a very big deal.
With a standard gasoline lower-duty engine like in most every car the tuning window is very small and typically dependent on very specific factors. By dependent, I mean that usually if you say have to push more fuel to a certain amount you have to have very specific supporting modifications for a very specific tunable range. Hence why these and others factors usually combine to make something like this be not only difficult but also potentially cost ineffective. The other thing to consider is one can make very strong power gains on just one specific application - turbocharger-specific or supercharger-specific. Tuning thus becomes focused on reaching a specific power value, and then advancing from there if such is desired to another window of tune-ability.
Total ratings: 260
Report this Post10-01-2013 03:40 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Detroit Diesel had an entire line of engines that were twin charged as OEM equipment... The twin charged concept has merits depending on the application.
thesameguy
Report this Post10-01-2013 06:10 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure the size of the engine is that important... historically it's the rev range (or lack thereof) that makes twincharging desirable... the bigger the rev range, the more desirable it is. VW has a production twincharged 1.4l, and has for many years, for example. High redline combined with relatively modest power goals and high responsiveness is about the ideal scenario for twincharging...
darkhorizon
Total ratings: 451
Report this Post10-01-2013 06:24 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its not.
There is some speculation that it helps to introduce a supercharger bypass as the turbo flow overcomes SC flow to increase the blower/turbo efficiency lambda. Under 500whp I doubt you would need to be concerned with this. The physics of twin charging is very forgiving and easy to calculate... That being the math shows favorable efficiency on both the turbo and the blower if you have a moderate to large sized turbo.
darkhorizon
Total ratings: 451
Report this Post10-01-2013 06:26 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
darkhorizon
Member since Jan 2006
Its not.
Tweeder
Report this Post10-02-2013 11:19 AM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was reading that in dealing with the heat issue of being twin charged, someone had suggested but no answer, lowering the boost at the supercharger from the stock 3.8 to a 4.0 and use a larger turbo. The theory is that there's less heat generated from 4 psi vs 8 psi.
Here's the link
http://www.theturboforums.c...fcab72ad8dfa934b73bc
[This message has been edited by Tweeder (edited 10-02-2013).]
Tweeder
Report this Post10-02-2013 04:04 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tweeder
Member since Aug 2012
Why would people bleed the supercharger boost off after a certain psi to let the turbo take over?
Justinbart
Total ratings: 119
Report this Post10-02-2013 05:21 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's not about pressure it's about flow and efficiency ranges.
Turbo 3800 E85 F23 5spd spec5
11.17@132.6
Tweeder
Report this Post10-02-2013 05:27 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
So they bleed off the boost to allow the supercharger to spin more freely to reduce the amount of drag thus allowing more air in from the turbo?
Tweeder
Report this Post10-02-2013 05:37 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tweeder
Here's a write up from someone that did a gtp.
http://www.scvt.net/index.p...ncharge-project.138/
darkhorizon
Total ratings: 451
Report this Post10-02-2013 09:50 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ehhh.. He is pretty far off base for the most part.
The eaton blower doesnt "make boost" Its just a blower that doesnt let air back out of where it just put it... it makes compression inside of the lower intake manifold... so if there is no pressure to make, aka its 15psi above and below the blower, you effectively have zero load on the blower. The bigger pulley is just an idea that underdriving the blower may gain you a half a horsepower due to less rotating mass.
Spiders1
Report this Post10-02-2013 10:47 PM Click Here to See the Profile for Spiders1Send a Private Message to Spiders1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Eventually the turbo will be held back by the supercharger. It becomes a parasitic at high rpm.
Tweeder
Report this Post10-03-2013 01:07 AM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wonder at what HP that would be?
dobey
Total ratings: 371
Report this Post10-03-2013 09:19 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not necessarily true. It depends on several variables, and in any case where it is true, the blower is already a hindrance to performance at that RPM by itself, as it would be a restriction to air flow regardless of whether there's a turbo before the blower or not.
As long as the blower can flow enough CFM to fill the needs of the engine's displacement at any given RPM, it will not be a restriction or parasitic, regardless of whether it is compressing air. It will simply plateau and stop adding power. Turbochargers are also afflicted with compressive limits, and if the cold side is unable to flow enough air to meet the needs of an engine at a given RPM, will also become a restriction at that RPM.
Spiders1
Report this Post10-03-2013 12:16 PM Click Here to See the Profile for Spiders1Send a Private Message to Spiders1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Even a tiny turbo like the ones on a stock Eclipse or an Audi can hit about 25 to 30lbs of boost before they become
inefficient. The same is not true for a supercharger either roots or centrifugal. I have heard of a 650 hp Lotus Elise
that is twin charged. It's on YouTube.
dobey
Total ratings: 371
Report this Post10-03-2013 02:45 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
PSI is irrelevant in terms of flow. 600 PSI or 10 PSI at 300 CFM is still only flowing at 300 CFM. If you're only capable flowing 300 CFM at any RPM where the engine needs more than that to remain efficient and make power, you're a restriction. For an engine to continue making power at higher RPMs, you need to be able to flow enough air into and out of the cylinder, for it to make that power (along with the fuel and spark requirements). The only thing adding PSI via boost does, is increase the pressure inside the cylinder, so that you make more power than you would at a lower cylinder pressure.
darkhorizon
Total ratings: 451
Report this Post10-03-2013 02:59 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Completely wrong. The blower works on pressure ratio, and as long as there is none, there is no blower. Its "parasitic" only in the form of rotating mass.
Wrong again. This is true of a dual compressor setup, but not this one. The blower "displacement" scales directly with the pressure coming into the turbo.. so technically at 14psi of boost, the blower has an effective displacement of an "m180" blower instead of a "m90".
Tweeder
Report this Post10-03-2013 03:33 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
When charging the supercharger with air from the turbo, you allow the super to work less harder in a sence claiming the loss in HP robbed from parasitic loss due to the belt.
