  headlight GEN 1
headlight GEN 1 by newfiejeff
Started on: 10-01-2013 10:02 AM
Replies: 4 (167 views)
Last post by: Dodgerunner on 10-01-2013 11:06 PM
newfiejeff
Report this Post10-01-2013 10:02 AM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
1986 2m4 5 speed
Do anyone have the schematic for the headlight system on a 1986? It looks like to me that they have it all disconnected and a switch to make the headlights come up but not go down put in the center console.
Bloozberry
Total ratings: 311
Report this Post10-01-2013 12:19 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is the wiring schematic:
It's a rather complicated circuit so here is how the current flows to the pod motors when the lights are turned on:
And here is how the current flows to the pod motors when turned off:
There's a good chance the previous owner found out his Isolation Relay was fried and jury-rigged the wiring in your car because the isolation relays aren't available anymore. If that's what you find when you go to reconnect everything, then there is a simple fix to bypass the isolation relay but retain all the operating features by jumping the wires like this:
Good luck.
newfiejeff
Report this Post10-01-2013 12:28 PM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can't see the pics as I am at work so it must be filtered but will take a look when I get home.
newfiejeff
Report this Post10-01-2013 07:50 PM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
newfiejeff
Member since Aug 2013
Thats the job the winter...thanks
Dodgerunner
Total ratings: 323
Report this Post10-01-2013 11:06 PM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can also go to youtube and search for Buddycraigg and headlight. He has a complete series of videos on how it works and how to test.
