  What part is this?
What part is this? by newfiejeff
Started on: 10-01-2013 05:37 AM
Replies: 6 (272 views)
Last post by: newfiejeff on 10-01-2013 07:49 PM
newfiejeff
Report this Post10-01-2013 05:37 AM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
1986 2m4 5 speed
I was replacing the alternator the weekend past and was under my car. There is a sensor fairly big with 3 wire harness that plugs in it, its to the right of the oil filter and just above the base pan. Is that an oil sensor or something? Whatever it is the prongs on it are corroded real good.
Blacktree
Total ratings: 350
Report this Post10-01-2013 06:44 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think you're referring to the oil pressure sender.
jimbolaya
Total ratings: 114
Report this Post10-01-2013 10:50 AM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is it this?
If so, then Blacktree is correct. This is off a V6, but they look similar.
Jim
[This message has been edited by jimbolaya (edited 10-01-2013).]
newfiejeff
Report this Post10-01-2013 11:27 AM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
Was a picture attached?
jimbolaya
Total ratings: 114
Report this Post10-01-2013 12:12 PM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm seeing a picture of a oil pressure sending unit. No attachment. Not sure what you are seeing. Maybe you have some type of filter blocking it or something like that.
Jim
newfiejeff
Report this Post10-01-2013 12:17 PM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah I am at work, will check it out when I get home.
newfiejeff
Report this Post10-01-2013 07:49 PM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
newfiejeff
Member since Aug 2013
Thats it...thanks...just need to clean it up!!!!
