  First time PFF post! I'll be prepping my l67+4t65ehd for install into my 2m4 soon.
First time PFF post! I'll be prepping my l67+4t65ehd for install into my 2m4 soon. by fisherlr777
Started on: 09-30-2013 06:59 AM
Replies: 10 (237 views)
Last post by: MstangsBware on 10-02-2013 02:46 AM
fisherlr777
Report this Post09-30-2013 06:59 AM Click Here to See the Profile for fisherlr777Send a Private Message to fisherlr777Edit/Delete MessageReply w/QuoteDirect Link to This Post
Been lurking/studying for well over a year now. Purchased my fiero last summer and have been slowly rebuilding/repairing it to be a half-way decent car. After several months of asking people to keep an eye out for 3800 n/a and SC cars that have been wrecked, I recently found a (deep breath) ROLLED buick park avenue ultra for 400 dollars. The engines running well, and now pulled from the car and i'm now prepping the build.
Heres my plan so far, I have a spare fiero engine cradle for the garage build.
WCF engine and trans mount brackets. and dogbone brackets.
Axles pieced together with store-bought axles (can i really use the driver 125c fiero axle with my 4t65e-hd?)
86-87 4-cyl throttle cable
stainless fuel hoses(if affordable, will be piecing together myself)
Stock park avenue exhaust manifolds (exhaust is not my strong suite, requires much more studying)
PCM and wiring: PCM will probably be sent off, but i really want to have full tuning control myself.
Being poor as hell, i would really appreciate any advice, i'll probably be asking tons of questions here.
MstangsBware
Total ratings: 459
Report this Post09-30-2013 07:35 AM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can not use store bought axles as all makers r different and nothing ever matches. Use OEM axles to build the Pass side axle. Yes to tge stock auto Fiero axle.
FIEROFLYER
Total ratings: 180
Report this Post09-30-2013 09:06 AM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
Save your money and buy a good mig lewder and make all your own mounts, brackets and exhaust. When you are done you will have what you need for less then buying it premade and still have a nice mig.
Study the diagrams and make your own harness then just get some one on here to program the PCM to the specs you want. Dan
DARN Cars now open with
Report this Post09-30-2013 09:10 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to the Forum! It's tough to do an engine swap when you are poor as hell.... Good Luck!
qwikgta
Total ratings: 84
Report this Post09-30-2013 11:23 AM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by FIEROFLYER:
Save your money and buy a good mig welder and make all your own mounts, brackets and exhaust. Study the diagrams and make your own harness then just get some one on here to program the PCM to the specs you want. Dan
Yea its just this easy. You should have it done in a month or two. :-)
Rob
fisherlr777
Report this Post09-30-2013 05:56 PM Click Here to See the Profile for fisherlr777Send a Private Message to fisherlr777Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the reply. By store-bought, i meant not used, but pieced together from other axles, (chevy beretta + fiero manual passenger axle, swapping out the bearings, i did some research)
MstangsBware
Total ratings: 459
Report this Post09-30-2013 08:49 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
U wany used OEM axles to build the Pass side axle with...
fisherlr777
Report this Post10-01-2013 04:49 AM Click Here to See the Profile for fisherlr777Send a Private Message to fisherlr777Edit/Delete MessageReply w/QuoteDirect Link to This Post
Will aftermarket axles not work? I want good, new bearings with good, new grease.
Report this Post10-01-2013 09:06 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Many of us Fiero owners have found that the original bearings are better quality than new replacement bearings.
darkhorizon
Total ratings: 451
Report this Post10-01-2013 06:36 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Beretta combo rarely works. I use the cavi 4t45 axles myself.
MstangsBware
Total ratings: 459
Report this Post10-02-2013 02:46 AM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Alright...One more time....Use only stock OEM axles to build Pass side axle not aftermarket junk axles. Just clean out old grease and add new if u want new grease. Stock OEM axles r built 100 times better then aftermarket axles. I build the axle for the Pass side if u need one built.
