  4.9l swap having problems with transmission 460e
4.9l swap having problems with transmission 460e by ts6681
Started on: 09-29-2013 07:40 PM
Replies: 5 (308 views)
Last post by: Darth Fiero on 10-01-2013 06:43 PM
ts6681
Report this Post09-29-2013 07:40 PM Click Here to See the Profile for ts6681Send a Private Message to ts6681Edit/Delete MessageReply w/QuoteDirect Link to This Post
The transmission shifts into rev nuet and drive but has no power it does not speed up when I accelerate. When I first start it after it has been sitting and shift in for or rev it will sit there and finally start to move. I know my inputs and outputs from the computer are ok. I suspect the internal pump. Is there something I am overlooking? The engine runs just fine starts right up and accelerates when I give it gas.
Zac88GT
Report this Post09-30-2013 02:28 AM Click Here to See the Profile for Zac88GTClick Here to visit Zac88GT's HomePageSend a Private Message to Zac88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have the vacuum line on the vacuum modulator (controls line pressure) hooked up?
ts6681
Report this Post09-30-2013 05:21 AM Click Here to See the Profile for ts6681Send a Private Message to ts6681Edit/Delete MessageReply w/QuoteDirect Link to This Post
yes and verified i do have vacuum. I have been doing some searching and found the brake switch input affects the PWM wich intern controlls the pwm sol. this controls the preasu. Not sure I have it connected
SERGE144
Report this Post09-30-2013 09:29 AM Click Here to See the Profile for SERGE144Send a Private Message to SERGE144Edit/Delete MessageReply w/QuoteDirect Link to This Post
Make sure you have 12 volts to the trans harness.
ts6681
Report this Post09-30-2013 07:46 PM Click Here to See the Profile for ts6681Send a Private Message to ts6681Edit/Delete MessageReply w/QuoteDirect Link to This Post
Alllready checked wiring several times. Going to add some more fluid even though it says its full at this point aint gonna hurt. Going to go to local caddillac dealer see if I can buy some time with one of their transmission techs.
Darth Fiero
Total ratings: 361
Report this Post10-01-2013 06:43 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
The first thing you need to do is scan the PCM and make sure the PCM is commanding all gears at the proper time AND that there are no codes setting that will cause the transmission to go into limp mode.
If the transmission goes into limp mode, you may only have 3rd gear operation (along with reverse, neutral, and park - of course).
Simply adding more fluid if it is already full is not going to fix anything. While overfilling will probably not hurt anything, it can cause the axle seals to leak.
-ryan
OVERKILL IS UNDERRATED
