  TFS Braided Brake Line Questions
TFS Braided Brake Line Questions by rbell2915
Started on: 09-29-2013 05:14 PM
Replies: 4 (419 views)
Last post by: rbell2915 on 09-29-2013 07:08 PM
rbell2915
Report this Post09-29-2013 05:14 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
We're replacing the lines on my car and we got the first on and it's leaking like crazy on the side connecting to the caliper. Any suggestions on how to fix this?
-1986 Pontiac Fiero GT
*October 2, 2012
seajai
Total ratings: 51
Report this Post09-29-2013 07:01 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you make sure to use a new copper washer on both sides of the fitting? The ends need to be tight to the lines as well. I got Fiero Store braided hoses on my car and had no problems with leaks.
Tweeder
Report this Post09-29-2013 07:02 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
Never done stainless brake lines, did you make sure to put on a new copper ring?
85 SE VIN 9
Report this Post09-29-2013 07:03 PM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
I bought those too, then I thought better of it and got regular rubber hoses. They have a much bigger connector on the caliper end. Otherwise you could tighten the hell out of them. Sometimes the connection face on the caliper is freshly ground on remans, maybe you need to grind the connection face. You're using new copper washers aren't you?
[This message has been edited by 85 SE VIN 9 (edited 09-29-2013).]
rbell2915
Report this Post09-29-2013 07:08 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, we used new washers on both sides. I believe it wasn't tight enough, but we thought it was. It was a silly mistake, but thanks guys!
