  Issue with my rear brake lights
Issue with my rear brake lights by blacknblue
Started on: 09-29-2013 01:56 AM
Replies: 3 (220 views)
Last post by: blacknblue on 09-30-2013 02:07 AM
blacknblue
Report this Post09-29-2013 01:56 AM Click Here to See the Profile for blacknblueSend a Private Message to blacknblueEdit/Delete MessageReply w/QuoteDirect Link to This Post
So only my third brake light and right hand side brake lights are lighting up with brake pedal depressed...Sometimes... Other times, they all work like a champ. After changing the bulbs, this still happens. I'm thinking i might have a bad ground possibly? Seriously i stink at troubleshooting when it comes to wiring. I don't even know where to start looking. Any ideas?
[This message has been edited by blacknblue (edited 09-29-2013).]
HarryT
Report this Post09-29-2013 02:10 AM Click Here to See the Profile for HarryTSend a Private Message to HarryTEdit/Delete MessageReply w/QuoteDirect Link to This Post
It could be corrosion in the socket or weak spring tension. Scrape and clean the contacts and check the spring tension where the bulb makes contact in the socket.
Harry
Report this Post09-29-2013 12:21 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rear sockets ground get loose. carefully bend the ground contact.
See my Cave, Lighbulbs
blacknblue
Report this Post09-30-2013 02:07 AM Click Here to See the Profile for blacknblueSend a Private Message to blacknblueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, i'll take a look at it in the morning
