  Only left turn signal works
Only left turn signal works by Atlanta1
Started on: 09-27-2013 07:09 PM
Replies: 1 (94 views)
Last post by: Ray_and_kevin on 09-27-2013 08:29 PM
Atlanta1
Report this Post09-27-2013 07:09 PM Click Here to See the Profile for Atlanta1Send a Private Message to Atlanta1Edit/Delete MessageReply w/QuoteDirect Link to This Post
My right turn signal and right hazard does light up inside and outside.
I did change the Flasher and still not fixed. Ground issue?
Ray_and_kevin
Report this Post09-27-2013 08:29 PM Click Here to See the Profile for Ray_and_kevinSend a Private Message to Ray_and_kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a failure right after I changed the right front bulb. In my case the parking light burned out because I still had turn signal. After the bulb replacement, no turn signal (or veeerrrrrryyyy slow).
Turns out the 25 year old metal for the ground connection gave out and when I took the bulb back out the metal tab fell out. Had to replace the bulb socket.
