  Series III S/C injector ?
Series III S/C injector ? by IROCTAFIERO
Started on: 09-27-2013 09:09 AM
Replies: 4 (113 views)
Last post by: qwikgta on 09-27-2013 03:23 PM
IROCTAFIERO
Report this Post09-27-2013 09:09 AM Click Here to See the Profile for IROCTAFIEROSend a Private Message to IROCTAFIEROEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am putting an 04 Series 3 3800 S/C in my 87 GT.
I am using the series 2 TB and ZZP adapter.
What are the differences in Series 2 and Series 3 injectors?
I have both fuel rails both sets of injectors and planned on using the S2 ones, but I would use the S3 if I can
MstangsBware
Total ratings: 459
Report this Post09-27-2013 10:51 AM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
U can use either as long as u wire in the right connectors. I perfer the S2 injectors myself with the S3 rail backwards.
IROCTAFIERO
Report this Post09-27-2013 11:16 AM Click Here to See the Profile for IROCTAFIEROSend a Private Message to IROCTAFIEROEdit/Delete MessageReply w/QuoteDirect Link to This Post
I certainly like the S3 rails better.
What do you like about S2 injectors?
Availability?
darkhorizon
Total ratings: 451
Report this Post09-27-2013 02:17 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
injector clips on a L67 harness are EV1 and l32 injectors are EV6 connector.
qwikgta
Total ratings: 84
Report this Post09-27-2013 03:23 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
not sure if its the same thing, but I am doing a 2004 3800 NA in my 88 GT and am running the car as a SII. I also used the SII TB and a ZZP adaptor. I used the SIII fuel rail/injectors and had to use the SIII wire harness for the injectors, wired up to the SII harness. I took the whole harness apart and ran each wire, one at a time, until the harness was done. Its not that bad, the injectors have two wires, a common pink one and a green, blue, yellow, pink, black, ? one. I'm pretty sure the colors matched the original SII harness. But bottom line its not that difficult to wire up the SIII stuff into the SII harness.
Rob
