  at the ropes end with this car!
at the ropes end with this car! by northstar
Started on: 09-26-2013 04:08 PM
Replies: 15 (432 views)
Last post by: solotwo on 09-27-2013 08:28 PM
northstar
Report this Post09-26-2013 04:08 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
drivers front and driver front side marker wont lite,,,all others are working...getting ready to give up, any ideas?
jb1
Report this Post09-26-2013 04:10 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
check ground and bulb? if both are good look for broken wire..
87 GT
(series II swap in progress)
85GT Northstar/ 4t80e
86GT 3800 n/a
My Build
Report this Post09-26-2013 05:11 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The amber light in front is a double filament bulb that sometimes fails and makes a circuit to ground. Does your turn indicator work?
Have you been to visit the Ogre?
http://home.comcast.net/~fierocave/sneakpath.htm
[This message has been edited by Gall757 (edited 09-26-2013).]
hercimer01
Report this Post09-26-2013 05:46 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
My car sat for a long time. The marker lites didn't work at first. I had to clean all the contacts in the sockets and on the bulbs with emery cloth and contact cleaner.
88 Coupe under construction
northstar
Report this Post09-26-2013 06:38 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
no turn signals either some bulbs in the back are dim too
northstar
Report this Post09-26-2013 06:42 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
northstar
Member since Aug 2013
ill try cleaning the P.O.S. IF THAT FAILS LOOK FOT IT IN THE MALL CHEAP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Report this Post09-26-2013 07:04 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
It will be a good deal for someone who knows how to fix it.
87FieroSport
Report this Post09-26-2013 07:18 PM Click Here to See the Profile for 87FieroSportSend a Private Message to 87FieroSportEdit/Delete MessageReply w/QuoteDirect Link to This Post
^ and for someone with more patience for an inanimate object.
Report this Post09-26-2013 07:49 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Side marker lights aren't double filament. They are the same bulbs that go into the courtesy and instrument panel. Do the marker lights illuminate with the parking lights on? If so, then you can discount a bad connection at the bulb. If the front and rear turn signals work on that side, then you can discount the flasher being the problem. If they don't, it's possible that one side of the flasher has gone bad. The flasher is located to the left of the steering column support bracket, kept in place by a spring metal clip.
northstar
Report this Post09-26-2013 08:15 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I GOT ALL THE SUPPLIES TO CLEAN THE POS EVEN BOUGHT ALL ...ALLL NEW BULBS JUST IN CASE A BAD ONE TRIES TO SNEAK THRU.. ITS EASY TO RUN SHORT ON PATIENCE WITH WIRING ISSUES,, THEY HAVE TO BE THE WORST PROBLEM TO HAVE WITH ANY VEHICLE ,,AND I HAVE WORKED ON A HECKOVA LOTTA CARS.....FRUSTRAITING.......................
84fiero123
Total ratings: 325
Report this Post09-26-2013 08:31 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I would rather pound my balls flat with a sledge hammer than hunt down an electrical problem.
that said, start with a trouble light and check to make sure you have juice, no juice follow the wires back to their ground, there is a separate ground for the side marker light and the parking light, make sure they are both clean and tight. both are under the hood but not connected together. then try putting your point of the trouble light on each of the contacts and ground the alligator clip . that will tell you if it is a bad ground or no power.
from there trace your wires back to find out if you have a damaged wire.
Steve
[This message has been edited by 84fiero123 (edited 09-28-2013).]
rbell2915
Report this Post09-26-2013 08:36 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
Before you work on the car again, I highly suggest you calm down. It's never a good idea to work on a car mad and frustrated.
-1986 Pontiac Fiero GT
*October 2, 2012
87FieroSport
Report this Post09-26-2013 09:07 PM Click Here to See the Profile for 87FieroSportSend a Private Message to 87FieroSportEdit/Delete MessageReply w/QuoteDirect Link to This Post
S***canned an employee for getting frustrated,
Hummed a wrench, bounced and cracked a window.
Take a night to relax.
I've left my car in pieces and called it a night over valve
Adjustment issues.
northstar
Report this Post09-26-2013 10:13 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
GOOD ADVICE NITE ALLLLL
f85gtron
Report this Post09-27-2013 06:03 AM Click Here to See the Profile for f85gtronSend a Private Message to f85gtronEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm having similar problems right now.... The ogre's cave is the place to be. Start with the ground connections in the headlight well. I think thats where my problem is anyways. I've got no park and an interior indicator illuminated all the time on that side......
solotwo
Total ratings: 62
Report this Post09-27-2013 08:28 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Being old cars I have found a few broken wires on the fieros I have owned that caused turn signal problems.
