  Need help! 1987 Fiero 2.5L (Page 2)
Need help! 1987 Fiero 2.5L by Mentor_Cards13
Started on: 09-25-2013 08:02 PM
Replies: 59 (1144 views)
Last post by: Mentor_Cards13 on 10-25-2013 05:04 PM
Mentor_Cards13
Report this Post10-20-2013 08:42 PM Click Here to See the Profile for Mentor_Cards13Send a Private Message to Mentor_Cards13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok bad news, was not fuel pump, everytime he tapped on the ecm started running right did it both with new ecm and old one, did the same thing, but I found a vaccum leak and it was to the a/c dont know if that's the problem, but it runs fine when you tap on ecm but we checked wires already it so wierd starting to get mad a aggravated and sad at the same time :,(
Report this Post10-20-2013 08:50 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Clean off all the contacts in the connectors to the ECM. You must have some corrosion in there.
cebix
Report this Post10-21-2013 02:22 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know if you read my thread but my symptoms started after the shop was fixing my A/C. So I guess that is worth checking. But I don't see any vacuum to my A/C. It's only a compressor that's running from the water pump belt and the rest is electric - no vacuum whatsoever. Maybe it's different on the 1987? Mine is a 1985.
Also I disconnected all the electric cables from the compressor and the belt itself and it didn't help.
Can you specify where have you found the vacuum leak?
[This message has been edited by cebix (edited 10-21-2013).]
Mentor_Cards13
Report this Post10-21-2013 04:08 PM Click Here to See the Profile for Mentor_Cards13Send a Private Message to Mentor_Cards13Edit/Delete MessageReply w/QuoteDirect Link to This Post
It's right by the alternator
Mentor_Cards13
Report this Post10-21-2013 05:16 PM Click Here to See the Profile for Mentor_Cards13Send a Private Message to Mentor_Cards13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Mentor_Cards13
Member since Sep 2013
Just replaced it no change
cebix
Report this Post10-21-2013 05:44 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
What did you actually replace? I don't see any vacuum hoses by the alternator on my car.
Mentor_Cards13
Report this Post10-21-2013 07:14 PM Click Here to See the Profile for Mentor_Cards13Send a Private Message to Mentor_Cards13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Probably because you're model is different my alternator is in the rear left side of the engine by the tail lights where is yours?
Report this Post10-21-2013 08:33 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
can we get a picture of that?
Mentor_Cards13
Report this Post10-21-2013 08:52 PM Click Here to See the Profile for Mentor_Cards13Send a Private Message to Mentor_Cards13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ill post it tomorrow you can see it in the YouTube video but its on the left back side of the engine
Mentor_Cards13
Report this Post10-21-2013 08:53 PM Click Here to See the Profile for Mentor_Cards13Send a Private Message to Mentor_Cards13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Mentor_Cards13
The wires are wrapped in a red plastic hose the only red plastic hose in the video lol
Report this Post10-22-2013 02:00 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
That's the cruise control vacuum diaphragm. It could be the cause of your bad idle.
Edit: Does your cruise control work?
[This message has been edited by Gall757 (edited 10-22-2013).]
Mentor_Cards13
Report this Post10-22-2013 07:46 PM Click Here to See the Profile for Mentor_Cards13Send a Private Message to Mentor_Cards13Edit/Delete MessageReply w/QuoteDirect Link to This Post
No my cruise control doesn't work at thought about it too
Mentor_Cards13
Report this Post10-22-2013 07:52 PM Click Here to See the Profile for Mentor_Cards13Send a Private Message to Mentor_Cards13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Mentor_Cards13
But um I believed I fixed that with the replacement vaccum hose
Report this Post10-22-2013 08:31 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The cruise control is hooked up to the vacuum system. You need to find the line that goes from the engine to the cruise control, disconnect it and cap it. See if your idle improves.
Mentor_Cards13
Report this Post10-22-2013 08:53 PM Click Here to See the Profile for Mentor_Cards13Send a Private Message to Mentor_Cards13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Will do keep you updated
Mentor_Cards13
Report this Post10-24-2013 08:21 PM Click Here to See the Profile for Mentor_Cards13Send a Private Message to Mentor_Cards13Edit/Delete MessageReply w/QuoteDirect Link to This Post
We'll, we actually found the problem, it was a bad fuel injector lol the most obvious thing was staring us right in the face, it works great now, I feel so stupid haha
cebix
Report this Post10-25-2013 05:44 AM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
What are the prices of those? Didn't you say in the first post that you replaced the injector? Is there a way to check the injector or did you just straight replaced it?
[This message has been edited by cebix (edited 10-25-2013).]
Mentor_Cards13
Report this Post10-25-2013 05:46 AM Click Here to See the Profile for Mentor_Cards13Send a Private Message to Mentor_Cards13Edit/Delete MessageReply w/QuoteDirect Link to This Post
I did but it was defective and we had it in partially and they go around $130.00 but it runs great now should not have any problems for a while lol
cebix
Report this Post10-25-2013 05:59 AM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
130 bucks seems a bit high. You replaced just the injector or the whole throttle body?
Mentor_Cards13
Report this Post10-25-2013 05:04 PM Click Here to See the Profile for Mentor_Cards13Send a Private Message to Mentor_Cards13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just Injector if it's put in wrong or not all the way in or defective it will act up badly
