  Rim size
Rim size by newfiejeff
Started on: 09-23-2013 10:17 AM
Replies: 2 (203 views)
Last post by: RCR on 09-23-2013 12:20 PM
newfiejeff
Report this Post09-23-2013 10:17 AM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
What size of rims and low profile tires can I put on my 1986 Fiero, currently it came with 14 inch?
newfiejeff
Report this Post09-23-2013 11:41 AM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
Let me get this right. If I stick with the same stock rims and tires the wheel well will be filled up...makes sense. So if I go with a low profile tire with the same size rim I am going to have a large space. So I would need to go with a larger rim with low profile.
Is this correct?
RCR
Total ratings: 102
Report this Post09-23-2013 12:20 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Is this correct?
Yes... Here's a tire/wheel size calculator.
http://www.rimsntires.com/specs.jsp
Plug in your current tire/wheel size and note the calculated height. Now play with different combinations, while trying to keep the height the same or close.
Bob
[This message has been edited by RCR (edited 09-23-2013).]
