  Never seen it asked about- 3800SC
Never seen it asked about- 3800SC by Lou6t4gto
Started on: 09-21-2013 05:33 PM
Replies: 3 (324 views)
Last post by: Lou6t4gto on 09-24-2013 04:05 PM
Lou6t4gto
Report this Post09-21-2013 05:33 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
When Swapping in the 3800SC W/ Auto, into a 1985 Fiero notch 4 cyl car, Does anything need to be addressed because of the Extra WEIGHT ?? Rear Springs ?
BV MotorSports
Total ratings: 189
Report this Post09-21-2013 09:31 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Stock springs will be ok, WS6 (GT) would be better, coil overs (300-325#) would be best. Just depends on how you plan on using it.
[This message has been edited by BV MotorSports (edited 09-21-2013).]
MulletproofMonk
Total ratings: 78
Report this Post09-22-2013 09:57 AM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Stock will be okay if they are in good order. If they are bad, then they are bad.
I have a set of rear 87GT springs on the floor of my garage. Probably cost more to ship them then finding some locally. I only pulled them because I went with Eibach springs all the way around... You wouldn't think 1" of drop is a big deal but it closes up the wheel gap nicely.
-Brian
Removing the roof panel
My HUD install thread
Modified stock air canister and base to 3.5 inch for 3800na
[This message has been edited by MulletproofMonk (edited 09-25-2013).]
Lou6t4gto
Report this Post09-24-2013 04:05 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Will probably go with Coil overs. How Wide a RIM can I use ( keeping the tire inside the top of the wheel Lip) ?
