  high amp alt. for a v belt 4 banger
high amp alt. for a v belt 4 banger by E.Furgal
Started on: 09-17-2013 09:35 AM
Replies: 2 (80 views)
Last post by: FlyFieroGT on 09-17-2013 10:24 AM
E.Furgal
Total ratings: 278
Report this Post09-17-2013 09:35 AM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
I remember someone addressing this but I can't find the thread, I thought I saved it to my list but it seems to not be there..
What was the stockers rated at 63 amps?
Thanks, As I have a feeling once the radio is in the alt won't keep up, as it is now when the heater is on,lights/wipers and the cooling fan starts the volts go straight to 10.5
yes the battery is tired it's getting replaced in the next few weeks
Rather have reserve power aval out of the alt and not need it, than push the stocker to it's top of it's rated output.
my 71 truck I used a 1986 t/a with 305ho alt as it's 105amp, no idea what to try on this car.
jaskispyder
Total ratings: 205
Report this Post09-17-2013 09:38 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
94 amps with a/c and 78 amps without a/c (from Rock Auto)
BTW, replace your battery with a good quality, high capacity version.
[This message has been edited by jaskispyder (edited 09-17-2013).]
FlyFieroGT
Report this Post09-17-2013 10:24 AM Click Here to See the Profile for FlyFieroGTSend a Private Message to FlyFieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Note: check and remove the engine and chassis grounds. Remove bolts clean all the metal surfaces until they shine reassemble and coat with dielectric grease.
