  Speedo Doesn't Work When the Engine is Cold
Speedo Doesn't Work When the Engine is Cold by FieroJosh1993
Started on: 09-15-2013 09:27 PM
Replies: 1 (86 views)
Last post by: steve308 on 09-15-2013 10:15 PM
FieroJosh1993
Report this Post09-15-2013 09:27 PM Click Here to See the Profile for FieroJosh1993Send a Private Message to FieroJosh1993Edit/Delete MessageReply w/QuoteDirect Link to This Post
As the title says, My Speedo Doesn't Work When the Engine is Cold. When i get in and start it up even if I wait 10 mins for the engine to warm up, when i start driving it jumps up and then down to 0. After I drive for 15 mins or so its fine. Not sure whats wrong. Please help.
Thanks,
Josh
steve308
Total ratings: 59
Report this Post09-15-2013 10:15 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
You might want to check the electrical connection where the wire 'tape' enters the instrument cluster. I had a similar problem and carefully disconnecting cleaning and re-plugging the wire solved the problem.
