  Help me identify a plug
Help me identify a plug by jimbolaya
Started on: 09-12-2013 01:58 PM
Replies: 8 (190 views)
Last post by: jimbolaya on 09-13-2013 10:59 AM
jimbolaya
Total ratings: 114
Report this Post09-12-2013 01:58 PM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry I do not have a picture yet, but I will get on as soon I get underneath the car again, but here's a description for now. It is a flat connector, probably 2 pronged. The other plug, it is mated to, probably has two tangs on it like a fuse, or something similar. The connector is located on the front side of the engine near the AC compressor. I already have two plugs in the AC compressor, and do not see a spot for this plug on the compressor. It is not the plug that connects at the deck lid. That one is already accounted for. Any ideas?
Edit: 86 GT, stock 2.8 motor.
Jim
[This message has been edited by jimbolaya (edited 09-12-2013).]
DaytonTD
Report this Post09-12-2013 02:03 PM Click Here to See the Profile for DaytonTDSend a Private Message to DaytonTDEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like the oxygen sensor connecter. The reason it is short from the harness is because the oxygen sensor itself has wires about 8-10" long to reach it.
jimbolaya
Total ratings: 114
Report this Post09-12-2013 02:16 PM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nope, the oxygen sensor is locked and loaded. Thanks for playing.
Jim
Total ratings: 260
Report this Post09-12-2013 02:23 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like it is the connector the AC clutch. It is a flat 2 prong connector that attaches right behind the belt on the front of the compressor.
DaytonTD
Report this Post09-12-2013 02:30 PM Click Here to See the Profile for DaytonTDSend a Private Message to DaytonTDEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could be that too, that one is more flat and plugs into the front of the compressor on the bottom.
Total ratings: 291
Report this Post09-12-2013 03:50 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
One is black and one is dk green? AC compressor clutch.
It most likely has a diode hanging between the two terminals on the back side and that is covered with nasty black duct type tape.
[This message has been edited by phonedawgz (edited 09-12-2013).]
jimbolaya
Total ratings: 114
Report this Post09-12-2013 04:11 PM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think we have a winner. I will still have to look, but I did not check the belt side of the compressor. I will update when I look at it tomorrow. I'm already cleaned up for the day, and to be honest I just don't feel like looking at it right now.
Jim
jimbolaya
Total ratings: 114
Report this Post09-12-2013 04:12 PM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
jimbolaya
Member since Feb 2007
That's it! Pluses all around, except for you phonedawg. You already have one.
Jim
jimbolaya
Total ratings: 114
Report this Post09-13-2013 10:59 AM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does it matter which way it is plugged in? I'm thinking no, or they would have made it with a connector that only allows one way to plug it in.
Jim
