  4.9 swap won't charge..
4.9 swap won't charge.. by northstar
Started on: 09-09-2013 09:40 PM
Replies: 12 (400 views)
Last post by: Neils88 on 09-10-2013 07:36 PM
northstar
Report this Post09-09-2013 09:40 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bought this 86 se with a 4.9 carburated engine in it..it runs great..I pulled the posi terminal off while running and the car stalled..it has a brand new alternater.where do I go first to attempt to fix this charging issue? Thanks c-note
trotterlg
Report this Post09-09-2013 09:44 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is a bad thing to do for sure. How do you know there is any problem at all? Larry
northstar
Report this Post09-09-2013 09:58 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've always checked charging systems out like that.their is no computer in this car..its all old school
northstar
Report this Post09-09-2013 10:05 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
northstar
Member since Aug 2013
trotterlg
Report this Post09-09-2013 10:34 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why do you think something is wrong? Larry
northstar
Report this Post09-09-2013 10:40 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well....I have a brand new battery in the car. And after a few days of starting and starting tge car it went dead..I jumped the car and removed the positive cable from the battery. The cc ar stalled..if the charging system was working it should've stayed running..rite? Their is no computer in this car
trotterlg
Report this Post09-09-2013 11:00 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does the red alternator light ever come on in the car?
jb1
Report this Post09-09-2013 11:45 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
if the charge light bulb is bad it wil not charge...
check with a volt meter and see if you get power to the exciter wire when you turn the key on it is a switched wire .
87 GT
(series II swap in progress)
85GT Northstar/ 4t80e
86GT 3800 n/a
My Build
[This message has been edited by jb1 (edited 09-09-2013).]
Reallybig
Report this Post09-10-2013 02:00 AM Click Here to See the Profile for ReallybigSend a Private Message to ReallybigEdit/Delete MessageReply w/QuoteDirect Link to This Post
I second this. When I did my 4.9 swap, I was very careful with the wiring; double, triple checked everything but when it started, there was no power coming out of the alt. After studying the prints for both cars I found that I didn't have a battery light in my instrument panel and for lack of this circuit, the alt wouldn't charge. That being said, I don't believe that the computer has anything to do with the circuits functionality and my issue it for the stock Caddy alt. If you have a different alternator adapted to the 4.9 then things for you could be different.
Pulling the pos. terminal off the battery forces the alternator to immediately take the full load of all electrical running systems in the car...kinda like kicking it in the nads. I used to leave my car running when jumpstarting others cars and found that the alternator would often fail in short order. By adding the cables, my alternator would have to immediately try to both start their engine and charge their dead battery...especially if the jumper cable connections were not 100%. Now I will only jump start a car with mine engine turned off and key out. It helps you to know if your connections are good too. Haven't lost an alternator since.
Good luck!
Mickey_Moose
Total ratings: 145
Report this Post09-10-2013 12:15 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
this...
northstar
Report this Post09-10-2013 12:48 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
got a new alternator today going to give it a try I have the old one tested and it was bad I will keep in touch
northstar
Report this Post09-10-2013 05:45 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
northstar
i can honestly say i own a fiero, and i have a stack of repair bills to prove it,,,always something,, anywayszzz new alternator ,,got it all kinda charge now,,great rite, well not really a parade just yet,, now my darn head light wont pop up, its not grinding or anything its just dead, although the light bulb comes on ,but the thing wont pop, is their a way to check the motor before i buy one one here, thanks again everyone><><>< c-note
Neils88
Total ratings: 56
Report this Post09-10-2013 07:36 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I know everyone does it (myself included), but disconnecting the battery cable on a running car can cause damage to the rectifier circuit in the alternator. This can reduce the life expectancy of your alternator...
Of course if it's not charging then no issues lol
