  No Power and Will Not Crank
No Power and Will Not Crank by labbe001
Started on: 09-07-2013 12:24 PM
Replies: 3 (153 views)
Last post by: phonedawgz on 09-07-2013 01:54 PM
labbe001
Report this Post09-07-2013 12:24 PM Click Here to See the Profile for labbe001Send a Private Message to labbe001Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Guys,
I got my 87 GT out of the garage this morning to carry it for a wheel alignment. It was stumbling really badly and I realized that it was very low on gas. I fueled her up and was ready to head to the tire shop. When I tried to crank back up, there was a click and everything died; no power at all to the car. The interior lights were not on or anything...I checked the battery to make sure it had a good connection. Just to be sure, I unhooked it and hooked it back up. As soon as the battery made connection, I noticed that the interior lights came back on. I tried to crank it and again, it clicked and immediately died.
Long story short, I noticed that if I disconnect power for a few seconds that the electrical power of the car is restored. But as soon as I try to crank it, there is a click and then nothing...no electrical power and will not turn over. I thought it may be the starter but would that cause the electrical power to go out? Thanks Guys...
Edit: to add that it is an 87GT, Manual Transmission, all stock..
[This message has been edited by labbe001 (edited 09-07-2013).]
labbe001
Report this Post09-07-2013 01:00 PM Click Here to See the Profile for labbe001Send a Private Message to labbe001Edit/Delete MessageReply w/QuoteDirect Link to This Post
ok....so i went outside to take another look around the engine bay and to wait on replies to my post.....and found my problem...lol
i had a loose connection on the ground side of the battery....guess sometimes it's easy to overlook the simple things...lol
thanks
84fiero123
Total ratings: 325
Report this Post09-07-2013 01:07 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
thanks
Always look at the battery and connections first when you have an electrical problem.
Steve
Total ratings: 290
Report this Post09-07-2013 01:54 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Many times dirty or corroded battery connections will do this. What happens is the battery cable only touches the battery terminal in one spot. All the other spots are corroded and don't connect. Attempting to crank the engine burns that spot. That is the noise you hear from the battery. Removing the cables, wire brushing the surfaces and reattaching them usually clears the problem.
Hi Guys,
