  hp tuners maf histogram
hp tuners maf histogram by yellow fever
Started on: 09-02-2013 03:30 PM
Replies: 2 (105 views)
Last post by: yellow fever on 09-02-2013 09:42 PM
yellow fever
Report this Post09-02-2013 03:30 PM Click Here to See the Profile for yellow feverSend a Private Message to yellow feverEdit/Delete MessageReply w/QuoteDirect Link to This Post
I cannot get my maf histogram to read anthing but zero. Can someone give me some help on what to fix. I have tried everything I could find on that subject and it still just reads zero. Thank fo any help.
Report this Post09-02-2013 06:54 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you in closed loop?
Normally the MAF histogram is reading out the STFT % for the individual MAF cells, which only happens in during closed loop.
It could be that your histogram isn't looking at the right sensor, or you have the filter set wrong, or there is a syntax issue with your scanner configuration... lots of possibilities.
It might be best to post your tune and scanner config on the HPTuners forum so others can take a look at your actual setup and point you in the right direction
yellow fever
Report this Post09-02-2013 09:42 PM Click Here to See the Profile for yellow feverSend a Private Message to yellow feverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the reply. What about running a LQ4 maf sensor. Would that make it not read.
