  Oil pressure sender/switch
Oil pressure sender/switch by trotterlg
Started on: 09-01-2013 11:21 AM
Replies: 1 (193 views)
Last post by: sco77 on 09-01-2013 01:28 PM
trotterlg
Report this Post09-01-2013 11:21 AM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is the oil pressure sender unit on a 3.4 and 3.8 proper to work with the oil pressure gauge and fuel pump relay on a stock 86 fiero? If so what year and model is correct? Larry
sco77
Report this Post09-01-2013 01:28 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
Use the 88 Fiero sender, use only the single sender wire to the gauge, change fuel pump relay and run the control wire from the PCM.
86 Fiero GT 4spd - L67 swap: VS cam, GenV. Needs exhaust (ETA 9/13) Build Progress
98 GTP - Some mods
