  Delete decklid safety switch?
Delete decklid safety switch? by sco77
Started on: 08-31-2013 01:13 PM
Replies: 1 (360 views)
Last post by: Dodgerunner on 08-31-2013 04:04 PM
sco77
Report this Post08-31-2013 01:13 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
On my manual I would like to bypass the decklid electric latch parking brake safety switch, what is the best way to do so?
86 Fiero GT 4spd - L67 swap: VS cam, GenV. Needs exhaust (ETA 9/13) Build Progress
98 GTP - Some mods
Dodgerunner
Total ratings: 323
Report this Post08-31-2013 04:04 PM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
The brake switch provides a ground then the brake is applied so the popper relay is energized. . So you have two choices. Either jumper the switch plug so that it is grounded all the time or remove the switch and tape it so it stays closed.
Or you can pull the popper relay and wrap some fine wire around the main contacts 2-3 and plug it back in so that the relay is not used anymore. Or make a jumper with two spade connectors and plug it into the relay socket. Then the switch will work all the time.
[This message has been edited by Dodgerunner (edited 08-31-2013).]
