Update System
  Clutch problems, I am confused
by zkhennings
Started on: 08-30-2013 12:50 PM
Replies: 3 (162 views)
Last post by: zkhennings on 09-01-2013 03:33 AM
zkhennings
Report this Post Click Here to See the Profile for zkhenningsSend a Private Message to zkhenningsEdit/Delete MessageReply w/QuoteDirect Link to This Post
My master and slave cylinders were replaced 3 years ago (isuzu slave)
Recently I was dropping the cradle and I tasked my younger brother with making sure nothing was getting caught on the drivers side. He did not notice the slave cylinder braided line getting crushed. It bent the solid part of the line attached to the slave around 7 degrees, and it crushed the braided line, though not fully. You can feel the braided portion is crushed. I have no pedal whatsoever anymore, but there is no fluid leaking anywhere.... I have not checked the bore of the master but I checked in the slave and along the entire clutch line and everything is dry as a bone, yet I have 0 pedal. The slave cylinder moves when the clutch pedal is pushed on, but it does not have enough strength the move the clutch, I have the slave unbolted at the moment. I am going to temporarily replace this with a section of hard line while I order rodney's kit, and hopefully my master cylinder has not developed a problem (though I can't fathom how it could have) and I am guessing this will solve my problems, but I can't figure out why I could have no pedal and have no fluid leaking if the master is ok.
Let me know, does anyone know what size fitting the slave accepts? I will probably just cut and flare the brake line with a coupler, or I may just buy a compression fitting. I will throw a loop into the hardline for the time being.
I would ideally like to get a custom hose made similar to the brake hoses where I could have a fitting on the hard line which screws into the clutch hose, and the clutch hose has another fitting on the other end which would go into the slave or have one more intermediate step with a female fitting that a short section of hard line could screw into. I live in an area where a lot of those custom motorcycle and automotive shops don't exist, the only store I have been to where custom hoses were made was a bobcat dealership.
fierosound
Total ratings: 286
Report this Post Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageClick Here to Email fierosoundSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Get Rodney's repair kit http://rodneydickman.com/ca...th=61&products_id=33
Report this Post Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageClick Here to Email fierofoolSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rodney's kit comes with the proper fittings to splice into your line. The compression fitting is the easier to install. I do know that the line is a metric. US compression fittings will leak and flaring the line attached to the car can be a problem.
Inspect your slave mounting bracket very carefully to see if it's broken. Though you're using an Isuzu slave, is it an Isuzu transmission? That slave is the same as used on the 85 and 86 V6 4-speeds. If you're ordering parts from Rodney, consider ordering his Isuzu double seal slave or slave rebuilding kit at the same time.
zkhennings
I temporarily replaced with an S shaped piece of hard line. Everything works now, and the old line really did not leak. I will be buying rodneys kit. I had no problem putting a bubble flare on the line from the MC. I spent 9 dollars in material.
I am still confused how no fluid could leak out but I lost my pedal.
