  What mods are required to use a F40 behind a 2.8L V6? Is it possible? Adapter plate?
What mods are required to use a F40 behind a 2.8L V6? Is it possible? Adapter plate? by hdryder
Started on: 08-27-2013 10:35 AM
Replies: 3 (360 views)
Last post by: FIEROFLYER on 08-27-2013 08:33 PM
hdryder
Report this Post08-27-2013 10:35 AM Click Here to See the Profile for hdryderSend a Private Message to hdryderEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is a local ad for a F40 with a G6 V6 bell housing for sale, and he states it can be used in Fieros.
I know the F40 is now used in Fieros with LSx power, but has anyone used it with a 2.8L 60deg., 3.1L or 3.4L?
Thanks for the help.
4thfiero
Report this Post08-27-2013 11:40 AM Click Here to See the Profile for 4thfieroSend a Private Message to 4thfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can use that Tranny, but I believe you will need an adapter plate.
You will also need to figure out the shifter, bcc this Tranny is out of front wheel drive cars, so the shifter on the tranny end is "backwards" for a Fiero.
I just installed a 5 speed getrag out of a 91 Sunbird and used Dickman's kit to convert it from FWD to RWD.
But yes it's possible.
P.S. you might also have to figure out a slave cylinder mod...im not sure if the Fiero Clutch line can hook up and work directly with the F40's slave Cylinder or if you need to rig something up. Im sure someone on here should know.
Archie
Total ratings: 547
Report this Post08-27-2013 12:36 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Drop Archie an EMail at Archie@v8archie.com & he can tell you exactly what you'll need to do that swap.
BTW, you don't need an adapter plate.
A
FIEROFLYER
Total ratings: 180
Report this Post08-27-2013 08:33 PM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
Nope no adapter but keep in mind the F40 speedo out put is 60,000 PPM compared to the Fiero 4,000 ppm.
