  Metro Cruise Disaster- well all most- 3800SC died- fuel problem I think
Metro Cruise Disaster- well all most- 3800SC died- fuel problem I think by solotwo
Started on: 08-26-2013 12:17 AM
Replies: 12 (316 views)
Last post by: solotwo on 09-05-2013 08:57 AM
solotwo
Total ratings: 62
Report this Post08-26-2013 12:17 AM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow what a feeling being in the heavy traffic and have the car die!
I could hear a funny sucking noise coming from the air cleaner and then it died. Tried to start it a few times while rolling down hill and being pushed off 28th street on to Division, but would not start. Sat there for a few moments which seemed like an half an hour, thinking it was heatsink, but the temp gauge was at normal. When I tried a few times the fuel pump had a different sound to it. It had a higher pitched whine which was not normal. So I was thinking that it was the fuel tank had some crud and blocked the filter. I had this happen to me 4 months ago. I had it towed home and changed the fuel filter. Well I tried turning the key a few times to see if the pump sounded different. When it did I fired it up and drove north down Division. Just before Burton it happened again. Not a good area to be in by the way at that time of night. Again waited until I heard the proper fuel pump pitch and off I go down a side street to Bucannon to Burton. Waited at the light hoping it would not kill. Got going west on Burton to head to the expressway. Almost made it, but had to turn off on a side street. Again waited for a few minutes then turned the key to listen to the fuel pump. Once I heard the proper pitch started and turned around to get back on Burton. Made it 131 only to have a red light. Once that turned I took off on to 131 north bound. made to the Franklin St entrance ramp. Again waited then took off made to the I-196 east bound exit and it quit again. Waited again and took off and didn't waste any time. Drove a little faster than I normally would but didn't want it to quit on the exit/entrance ramp. Little bugger corners pretty good a speed. Made to Fuller only to have a red light. Stayed running and made it another 10 blocks to home. What a night. Left the car out overnight to let it cool down.
This morning I had a Knights of Columbus event that I had to attend. Darned thing started up and ran great the several miles I had to travel. Same coming home.
My first thought was I have a fuel problem. But this time I didn't have half a tank but I was almost full. So then I thought it acted like the old carb days when you would get vapor lock. But several weeks ago I traveled out to Coopersville to cruise around town and then back home & no problem. I picked up a new fuel filter that I will install first thing tomorrow.
I am also thinking it may be tied to the ignition?? Don't know. I have had from day one of ownership a random miss at partial & full throttle and in 4th lock up. So I installed new plug wires. Ran fantastic for about 2 weeks then back to normal. Last week I installed new NGK spark plugs. All but one of the old plugs were a little darker than what a normal plug would be, number six was blacker making me thing that may be I might have a situation with the coil for #6. New plugs seemed to help a little but the random knock was still there. Is it possible that the heat may have caused the ignition to shut down? But then again the fuel pump would not have sounded different. Oh I have also noticed when accelerating it seems I have a small exhaust leak somewhere. Not sure if that has any relevance. The car does seem to run a little rich, but I think it is because of no egr and no cat.
Any ideas what I should look for?
Thanks,
Steve
MulletproofMonk
Total ratings: 78
Report this Post08-26-2013 01:08 AM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just got my 3800na on the road. I did start the motor a dozen or so times before getting it on the ground.
I decided that I didn't want to risk burning out the fuel pump prematurely so I decided to "HOT WIRE" the fuel pump using the instructions on Ryan's website. http://www.gmtuners.com/fiero/hot_wire.htm
People debate if this is necessary or say their car is fine without ever doing it. Personally I didn't want to risk the $130 Walbro pump when I could do the "HOT WIRE" for $20 or less (I had a relay from the junkyard in my pile o' stuff)...
EDIT:
If you have an ODB2 connector, you could see if you are getting any codes.
-Brian
Removing the roof panel
My HUD install thread
Modified stock air canister and base to 3.5 inch for 3800na
[This message has been edited by MulletproofMonk (edited 08-26-2013).]
Total ratings: 460
Report this Post08-26-2013 06:29 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Next time it happens, loosen your gas cap.
It's possible that the vapor canister is blocked and not allowing air into the tank. Once so much fuel is pumped out it creates a vacuum.
This happened to one of the guys in our club. Exact same symptoms. A different vapor canister resolved the problem.
Praise the Lowered!
Report this Post08-26-2013 09:34 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
+1
It's something that corrects itself by sitting, so it's either that or the fuel filter...(or both). All that idling on 28th street brings out the flaws in a lot of cars...the traffic cops were no help at all.
[This message has been edited by Gall757 (edited 08-26-2013).]
solotwo
Total ratings: 62
Report this Post08-26-2013 09:56 AM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
EDIT:
Thanks for the info. I have a connector that was made for the 99 GP ecm. I didnt make it, PO did. I have tried scanners at work(dealership) but they would not work. I tried with key off and key on. PO says he thinks he wired it to be key on. Any way will not work for me.
solotwo
Total ratings: 62
Report this Post08-26-2013 09:59 AM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
solotwo
Member since Jun 2002
Thanks for the info. Car doesn't have one, at least that I can find.
[This message has been edited by solotwo (edited 08-26-2013).]
solotwo
Total ratings: 62
Report this Post08-26-2013 10:01 AM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
solotwo
Originally posted by Gall757:
+1
Thanks for the info. I think I saw you when I was heading west on 28th. New fuel filter is going in just a few minutes.
Justinbart
Total ratings: 119
Report this Post08-26-2013 10:21 AM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
The vacuum in the fuel take sounds plausible.
You could tape a fuel pressure gauge to your window and watch that when it starts to act up. That will tell you if there is a fuel problem.
Turbo 3800 E85 F23 5spd spec5
11.17@132.6
solotwo
Total ratings: 62
Report this Post08-26-2013 12:37 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
car doesn not have a fuel canister for emissions.
Hmmm I wonder if the expansion tank has some issues.
solotwo
Total ratings: 62
Report this Post08-26-2013 12:39 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
solotwo
Thank you for your suggestions. If it happens again I'll try the gas cap and see if there is vacuum there. I think I will try the gas cap every day.
I'll look into doing the fuel pressure gauge. Would/could I tap into the fuel line heading to fuel rails?
MulletproofMonk
Total ratings: 78
Report this Post08-27-2013 07:59 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Look on the back of the fuel rail. There should be a black cap over a Schrader valve...
-Brian
[This message has been edited by MulletproofMonk (edited 08-27-2013).]
solotwo
Total ratings: 62
Report this Post08-28-2013 12:59 AM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you mr monk.
solotwo
Total ratings: 62
Report this Post09-05-2013 08:57 AM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll try Harbor Freight and see if I can find a gauge.
