  Turn signal issues
Turn signal issues by pontiackid86
Started on: 08-25-2013 03:19 PM
Replies: 2 (149 views)
Last post by: pontiackid86 on 08-25-2013 03:45 PM
pontiackid86
Total ratings: 344
Report this Post08-25-2013 03:19 PM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm having a realy hard time pinning down what is the matter with the turn signals on this car. when I got it they just plain did not work, I found that the was flasher was missing, replaced the flasher now the 4 ways work fine but the turn signals will not work, tried getting a new switch hooked it into the plug and flipped it and they still will not work, any ideas? the car is a 1986 SE
jb1
Report this Post08-25-2013 03:40 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
which flasher did you replace? one on the column or the one by the heater core? I am assuming the one by the heater core since it is for the hazzards , try the one on the column if you have not.
87 GT
(series II swap in progress)
85GT Northstar/ 4t80e
86GT 3800 n/a
My Build
pontiackid86
Total ratings: 344
Report this Post08-25-2013 03:45 PM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
I was looking at the wrong one found the plug for the other one hanging on the driver side... Thanks and +1 for ya... not to go buy a hazard one. one of the P/O's removed both flashers
[This message has been edited by pontiackid86 (edited 08-25-2013).]
